I've created this thread because I'm frustrated on a path forward during a real electric blackout caused by some event or a California "scheduled" blackout. The Tesla warranty only allows things plugged into the wimpy 12V cigarette lighter port. Using an inverter to clip-on to the 12V battery is the preferred method in an ICE car, but we know that this is driven by the Tesla 12V charging circuit and it might complain. And the 12V route is too wimpy anyway for my needs. Ideally, we would just use the 400V main battery and an inverter, but that involves disconnecting the 400V cable and the Tesla computer might trigger the safety disconnect. Tee'ing off the 400V line seems like it should work, but the computer might see this as a phantom-drain and trip something.
So at this point, the best concept that I can think of is to:
In googling around, I'm not able to find the right combination of search words for this setup. Power goes out a couple times a year, and California seems to be trying really hard to make it worse. I have a farm in the country, so the utility repair crews takes longer for me than for folks in the city.
If the 400V battery gets low, I'd put the tires back on, run down to the nearest SuperCharger that has power, charge-up, then come back home.
Keep in mind this is only in case of an emergency (just like my two 240V whole-house window A/C units are there in case of an emergency). But when it is 110 degrees outside, doing without A/C is not an option. Before the Tesla, I'd pile the family into a car and we'd just go to a movie theater for many hours or a hotel is the outage is for days. But with 80kWh sitting in the driveway, I'd like to use it.
Any recommendations on a viable path forward?
Thanks,
Scott
PS yes, yes, I'm the perfect candidate for a PowerWall and solar. Can't afford it right now and would wait for an LFP PowerWall anyway. Looked at EnPhase but they quoted $60k. Nope, I'll buy 4 generators instead to mount on my MYLR. I won't do gas-generator backup; lots of neighbors had them at one point and discarded them for all of the usual reasons.
MYLR | Red ext | White int | 19" | 5 seats | tow | no FSD | made/delivered Oct 2021
- jack the car up,
- remove the wheels,
- attach generators to each of the 4 (so that the load is balanced),
- attach a big pure-sine inverter to those,
- set cruise control to a constant speed,
- plug my 240V AC loads into the inverter (240V well pump and two 240V window A/C units)
Thanks,
Scott
