I’m hoping for some words of comfort from a more tech-savvy member than me …
I noticed a Porsche charger at a hotel and thought that I would give it a try. After all, “What’s the worst that could happen” (!)
My 2016 pre-facelift MS only has the small Type 2 connector ... which took the Porsche plug. After a few handshake messages on the unit, charging started at 16A.
I looked in the car and saw that the in-car display showed 235V and 16/16A … quite normal and expected. However the charge rate was showing as 10kW … NOT the expected 4kW (as 16A x 235V = 3.7kW).
The “time remaining” seemed to reflect 10kW too. If the 16A is correct (being something that the car and charger agree on) then the voltage must surely be much higher than the 235V that the car is “expecting” (and designed for). I decided to disconnect. I then noticed that the charging plug had a small etching on it of a high voltage number – ISTR ~ 400V. Perhaps I dodged a bullet (or a conflagration !).
Can anyone explain what was going on please … and is it safe ?
Does anyone routinely use Porsche chargers ?
FWIW my car has had the CCS upgrade and therefore a new module inside the car – I don’t know if this has any bearing on Level 2 charging or not.
