Yeah my car seems to be fine and I drive a lot my habit has been to atleast every 3 weeks charge to 95 and occasionally 100% but I Dnt let it sit very long like that thoHello, is there any problem with the car or does it perform normally? Interestingly, there's bigger difference when topped then partialy discharged. I'd try to charge it to approx 95% and let it stay for few days and control the difference. If the BMS works, it should lower the other cell's voltages according to the lowest cell (77).
I see yeah I should try that and give a little more time to sit at that SOCYes, it is not healthy for the pack. But for starting of the balancing process I have read the SOC must be above 90%.. it also makes sense to have it balanced like this and not in the middle or bottom of SOC. So I'd suggest to charge to approx 95% and let it sit lets say 2-3 days and see if there's any improvement..
Guys...Please help me understand these numbers from SMT..car is model S 2015 70D
DC Charge total: 14135 kWh
AC Charge total 37769 kWh
Charge total 65536 kWh
The diff between Charge - (DC+AC) = regen.
Which makes sense...
Next I compare my total car mileage: 223.766km and the charge total ... I calculate average consumption of 29 kWh/100km...which is too high.
If i do the calculation without the regen energy i get the 23 kWh per 100km. Which is a bit better. But I believe the regen energy should be included, right?
Why I bother with this is because my car's battery is without the sticker and as I bought it 2nd hand I have no history of it...
I guess you are right, my mind was not going in the right direction with this...because for regen to happen first the energy needs to be inputted
It's not like that... It's about the difference between what consumption is displayed on the IC vs the real consumption for the driven kms. That difference is as already explained caused by things such as vampire drain, preheating, camp mode...just all the consumption while car is standing + the loses during charging and discharging. Older Teslas unfortunately doesn't display this consumption. So the 23kWh/100km is perfectly normal long term measurement.So the total cars consumption is 23kwh/100km...which is a bit higher, because my last 25.000km is 19kwh/100km. so either the previous owned drove the car faster
