Just to let you know that I have been using TM Spy with the Carista scanner on an iPhone 7 using iOS13.
Started at V0.06.58 en and has been working absolutely fine. Has worked on every version until V0.6.62 which I updated to this morning and whilst it shows connected/green and graphing in the bottom right-hand corner, but no data is showing up.
Tried all the other screens, detaching and re-attaching the Carista, re-booting the iPhone, but no change.
That is not the Graphing screen.
There are two "Screens" in the current TM-Spy. One on the left and one on the right. You swipe left/right to select or tap the left/right chevron centered on the edge.
The left screen displays Custom screens which can be values and or gauges.
The right screen displays Graphs. For Model S/X there are currently 5 graph (tap center to cycle through).
- Battery Cell voltages
- Battery Voltage Histogram
- Battery Temperatures
- Saved Graphs (where you can select previously saved graphs to review)
- Graph where you can "Start Graphing", "Select Recipe" or "Reset" the graph.
For the Model 3 there are only two graphs.
You should not be going into Settings/Options and selecting the "When app starts, data capturing starts" unless you know what you are doing and have previously select the Recipe to use.
In any case you need to go to the right screen and then tap the center to select the graph that has "Ready to capture XXX Frames" or "Capturing XXX Frame data" on the second line. That is the only place you are going to see the data being captured.
