Turbo3
Just uploaded Android version 0.1.30 that fixes a bug that caused TM-Spy to crash if you had uninstalled it then reinstalled again.
Yes, the voltage of the 60 and 75 pack are the same. Though there are more than 84 cells. The original 60 pack had 384 cells per module and 14 modules. It's unknown what the current 60/75 has (I've looked and it appears nobody has ever taken apart a newer 75 pack), though it almost certainly has more cells than the original. My best guess is 414 cells per module.
As a reminder, post 138 of this thread shows the Sept 2015 (and later) Tesla S and X Tesla Diagnostics Connector (TDC), and its location behind the passenger side "hockey-stick" trim piece.
I believe that Chris TX still makes a 4-wire adapter from this TDC to an OBD connector, which he sells for $38, it appears.
You'll need to modify that cable to make it work with the TDP behind the cubby.
The OBD2 connector under the dash is useless for getting data like this. If you're looking for a pre-made cable,
I have this in the classifieds.
X_102_02161840.txt is a sample fIle included with the app. Your data should be in X_102_1704011429.txt. If you already know this, are you saying that your file was also limited to exactly 7500 records?Dropbox - X_102_02161840.xlsx
What I'm trying to figure out now is if there are more logs somewhere or longer ones. It seems to have stopped logging after 7500 records.
Darn. Didn't know that. That means I really didn't capture anything. The other file only has ~4100 records, so it only captured about 40 seconds worth of an hour of driving? Is there a time limit? It said it was logging the whole time and the LEDs were solid on...
I don't use the X files when I want to log the 102 messages. I use the ELM trace function at the bottom of the Settings page along with the Options dropdowns to select 102 messages. It does not give live graphing (that I know of), but the trace file found in the Debug folder does include timecodes and I have yet to find a recording limit.
There is live graphing. I run it every time I drive. Then I scroll back and find the fun times - high power runs. Here's a sample screenshot.
I should have specified that my method is for when I want to get the messages to my PC. Have you been able to get the underlying data for your graph above transferred to a PC?
