I'd be willing to try it on my 3 using the same setup I was able to get working on my S... anyone know where the port is?Would be interesting if someone could get TM Spy running on the Model 3. Are the CAN decodes the same? What about the diag connector?
So, just out of interest, this is how the inside of my OBD dongle looks like. The top cap pops off easily. Does your's look the same or is it different? Just curious if there are different innards for the same outside package and label...
I guess they have been using the same case and label for years with different innards. That's why I posted the Amazon link for the exact one I have that appears to work...The interior of mine is way different than yours!
I had this setup for Model S but would like to setup for my Model X, too. Have a few questions...
1. Is it possible to store the TDC-OBD2-Bluetooth OBD2 adapter in the space under the cubby, where the TDC connecter is originally hidden? It looks very small.
2. Which Bluetooth OBD2 adapter is recommended? I was using ELM327 (blue transparent case, relatively small) and it worked fine.
Here is the one recommended by the TM Spy guy:
LELink Bluetooth Low Energy BLE OBD-II OBD2 Car Diagnostic Tool For iPhone/iPod/iPad https://www.amazon.com/dp/B00QJRYMFC?ref=yo_pop_ma_swf
Thank you, @worldburger for the recommendation. Will try that one. I think I connected ELM327 with BLE on Android so that shouldn't be a problem.I believe you can store it under there. Without wiring a switch, the BT OBD adapter will draw power though.
Does anyone with a 100D know what the voltage is with a 100% charge?
No, unfortunately, but I ordered the cable from here.Were you able to get a hold of @Chris TX ? I have not been able to get a response on a cable and I'm ready to test this software.
Diagnostic Port IndexCan someone tell me a source for a pre-2015 Model S OBD cable (specifically for 2013 MS)...Lacking that, a pin out and diagram so I can make my own?...
There is a lot of data shared. What data specifically?...I noticed that users do not actively share data about their cars and I would really like to chat about some of the data graphs...
