Another 100% to 10%, back to 100% cycle is complete.
Car is now showing 230 mi displayed range. Seems to be improving my range about 5mi each time that I do this, roughly 2% increase. Maybe if I keep repeating it I'll get a long range model 3
I'll see if this pans out to actual increased kwh capacity in the battery.
I wonder if they reset the BMS in V10, and maybe it's fallback safe starting point is ~5kwh away from max, which happens to be the SR- range on my car. When it starts charging past the 220 mi point, it retards the charging current. Below 220 mi, it's charging at 271Vac at 24A. Above 220 mi, it starts lowering the current. At 226 mi of range, charging current was 6A.
I don't trust that the trip meter is 100% accurate and includes all energy usage.
Please... We're not talking a 1-2% discrepancy here, we're talking closer to 10%. You can only question it so far, however the car was fine prior to V10. Reminds me of lab partners trying to explain away why their circuits didn't work because of rounding errors, component tolerances and multi-meter inaccuracies. If the project is off by 10%, it's not rounding errors...
The car isn't going to consume 5kwh sitting still for 30 minutes either.
Prior to V10, 80%, my regular charging max corresponded to 195-200 miles of displayed range, every single day. I have more than 5000 miles on the car, and have had it since early June. Post V10, it corresponded to 175-180 miles of displayed range. If you want to ignore the range in distance, and instead use %, my daily commute round trip would take my battery from 80% to 60-65%, and consumed 13-15kwh. Now it's taking the battery down to 50-55%, for roughly the same 15kwh. I'm in SoCal, with a consistent commute, with zero traffic and temperatures haven't varied that much. There certainly wasn't a change the day before V10 rolled out, and the day after, yet I experienced an immediate difference in estimated battery capacity after my round trip commute.
