TunaBug
USB music hasn't worked for me in a long time; several software releases. The same stick that worked "perfectly" (using voice commands to resume playback) now never indexes. I never see a USB input on the console.
Tried another stick, and same thing. Same USB port will charge my phone, so I don't think it's the port (neither works anyway).
Their software reminds me of the worst days of Microsoft; bugs don't get fixed, there's no one to appeal to, and no one at the company cares anyway.
It sounds like the car isn't seeing your music. Disabling USB music playback because there is no USB music is very different from having a bad USB music playback app. The fact that a port works for powering your phone only means that it provides power. If the cable to the port is flaky such that the port has power but no data, then what do what you describe.
I would figure out why the car can't see the music. Perhaps start with a known good scenario, like getting USB music to show up using the glove box port which, presumably, you know works for USB data because of the dashcam? If you cannot get that to work, then it's the USB stick, or perhaps the way you formatted it (for example, are you using a supported filesystem?). Then once that works, move the known working USB music stick to a different port.
Or another thing to check: look at which sources you have enabled in the music options. Maybe you or a passenger accidentally disabled USB playback as an available source.
