So Model X and S owners can't use the new chargers, right? Does that mean that we will have to wait until an old charger is available in order to charge, and that some locations might not have any old chargers available at all to charge my Model X?
No, that's not true at all. Why did you get an idea like that? All of the announcements about it just said that the very high rate capability can't do anything better for the older cars.So Model X and S owners can't use the new chargers, right?
Rancho Mirage is not a v3 Supercharger. It's actually more the other direction of lower power. It is an urban style Supercharger, as you can see from that body style they have. Only the urban ones look like that. Those have a maximum power of 72kW.I believe I used a V3 charger this am at Rancho Mirage, CA. I was very confused by the numbering as it appeared my cable came from a receptacle with no number below it. The I saw a single row of charges and it was clear the "hoses" we plugged into the wrong holder on the back to back SCers. So, being the anal person that I am, I put all the charging cables in the right spot.
I'll try and pay more attention next time, but my car is a 2016 X so I couldn't use higher V3 power if it was available. I understand from another post that these are "urban" chargers with even less power that a standard charger...never knew there was such a thing..It did charge me from 55% to 90% in about the same amount of time as any other charger.Hi Beths11,
Thank you for returning the cables to their rightful positions...
What Max Kw of MPH charge rate did you get?
Thank You,
Shawn
There are pros and cons with the urban ones. They have a lower cap on the upper end, but they do not do the heavily uneven splitting like the normal ones, which frustrate people sometimes, where they are only getting 30-40kW because they are the secondary car. Urban ones are always an even half and half split, so you can get that solid 72kW, even if you're sharing.I'll try and pay more attention next time, but my car is a 2016 X so I couldn't use higher V3 power if it was available. I understand from another post that these are "urban" chargers with even less power that a standard charger...never knew there was such a thing..It did charge me from 55% to 90% in about the same amount of time as any other charger.
