v7.1 (2.15.50)
Discussion in 'Model X' started by Gas Guzzler, Apr 4, 2016.
Tags:
  1. Gas Guzzler
    Gas Guzzler Member
    San Francisco, CA
    Has anyone applied the v7.1 (2.15.50) update yet? Just got the update this AM and didn't notice any bugs. Might be my imagination but my passenger side door seems to open/close with a little more predictable results.
  2. Waldek
    Waldek Member
    Los Angeles, CA
    my update in progress :) will report if I see any difference here. I was trying to find any information about the update before it happens... but it showed update is available and actually no additional details about it... so not sure if I am updating to 2.15.50 but I suppose so since it is happening now too. My version was 2.15.16 before I started the update.
  3. Waldek
    Waldek Member
    Los Angeles, CA
    my update just finished. I noticed that driver front door opens for auto-present a bit earlier than before on the approach to the car and it opens more than before if it has space. on 2.15.16 when doing something in the garage around it was inconsistent with opening and sometimes I was bumping into doors... now seems more predictable and more consistent. I can't see any change in FWD opening behavior. I don't see any new features or any changes in the user interface other than saying it is on 2.15.50 now
  4. Waldek
    Waldek Member
    Los Angeles, CA
    also on my driveway that is not very steep but not flat either it used to just open driver doors just a bit so you would need to use your hand to open it more to get in. Now it opens driver doors as auto-present fully. FWD works good in both conditions now and before.
  5. mtimmy
    mtimmy Member
    sfo
    it solve my horn problem
  6. guidom
    guidom Member
    San Diego, CA / Tijuana, Mexico
    It seems like the auto close of the two front doors is a bit stronger after the update.
    Note that since I had to get the doors recalibrated in the first day since delivery (March 25th), I have had basically no problems with the front doors. I'm very careful not to interrupt them while they auto open, but almost 2 weeks later, it seems like a past problem. Maybe the software updates make the auto-open doors much less prone to "miscalibration" coming from interrupting the doors when opening?
  7. Waldek
    Waldek Member
    Los Angeles, CA
    I have a horn that make just a "sneeze" sound... but 2.15.50 did not fix it. When trying to honk through the iPhone Tesla App then it sounds correctly. But when pressing on the wheel it just "sneeze"... I guess I would need some day to go to SC and get it fixed. I am sure they will take care of it there.
  8. ronmerkord
    ronmerkord Member
    Fillmore, CA
    I was happy to see that with the new update, you no longer have to hold the button on the second row seats to move them forward / backward. Just touch it once and it moves all the way forward.
    Ron
    Sig X VIN #484
  9. cclaygo
    cclaygo Member
    United States
    Mine did that before the update....Not sure if that was new on this update.
  10. loganintx
    loganintx Member
    Austin, TX
    My seat did that at the Meet Model X event in mid march in Austin.
  11. HoptownT
    HoptownT Member
    Hopkinsville, KY
    This update seemed to have messed up my autopresenting door. Worked fine before exactly as it was designed to do. Now is slowly opening about 20 degrees (even when approaching from rear of vehicle) and is stuck, hard to move, then will eventually release to manual control so I can fully open all the way. Otherwise I have to sliver into the driver's seat.
  12. mtimmy
    mtimmy Member
    sfo
    my horn stopped working again., looks like a buffer overflow issue
  13. mercc3650
    mercc3650 Member
    Dallas, TX
    Service center said the new update should make the front doors work much more precise, as some have stated above. Didn't know about the horn issue, but mine was fine.
  14. 4sevens.com
    4sevens.com Member
    I just updated to v7.1 (2.16.17)
  15. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    Any improvements?
  16. 4sevens.com
    4sevens.com Member
  17. engle
    engle Member
    My guess is they had to push that out to support the Model X 75D instead of 70D. They also needed new graphics for the redesigned front of the Model S, charging 48/72, and bioweapon defense mode option. Does the X and S share the same firmware? (sorry for the ignorant question)
  18. GottaGetRidOfICE
    Boston
    My X is at SC because yesterday I simply couldn't get the driver's door to latch. Tried everything they recommended on the phone, they drove out to the parking lot where I was to give me a loaner S. My mobile app tells me they applied the update, and they also mentioned a firmware update
  19. DRock
    DRock Just some guy.
    Mountain View, CA
    Autopilot can now take us on the Rainbow Road!
    (pull the activation lever four times in rapid succession).
  20. sukhi
    sukhi Member
    Palo Alto
    I updated to 2.16.178 but not perceptible changes so far
