Here is the current bug list a of .40 in the Model X. There were several bugs fixed in .40 and these are the ones that are left. Can Model X owners confirm these are valid for them as well?
Media Player Bugs as of .40 of v8
1. Search
SEMI-FIXED (text input search works, voice search is hit or miss) Some instance of “ghost results” from previous media that is no longer plugged in. Selecting these items causes the Media Player to not play anything. There should also be an option to apply preferential treatment to search results (USB vs. streaming) and/or eliminate certain sources from results by user preference / Streaming people will want it one way (remove USB results), USB media people will like it the other way (remove streaming results) / Not all results are displayed when clearly there are more matches / What does “Top” mean in search results?
2. Playback Resume
Tracks still reset to beginning when exiting and then returning to the vehicle. Observed slight causality with track resetting when a driver returns to the car after longer than 15min from leaving it – need more testing / passenger door status change may also affect this
3. Bookmark Feature
Especially in light of the ‘Playback Resume’ error, request feature to "Bookmark" exact place (time and album) in audio track and save 3-5 different slots for resuming later / critical for audiobooks and podcasts played via USB / Trying to find an exact timestamp in a file can be dangerous while driving. Allowing a “Favorite” to save the current timestamp and album would suffice for this feature or it can be a separate section: FAVORITES / RECENT / BOOKMARKS
4. Shuffle/Shuffle Toggle
Shuffle is much better, however, there are hints that it is still playing the same set of songs depending on either which song is selected or how many times the shuffle button has been toggled. Entering into the car for the first time of the day results in the last playing song from the night before to play from start but then next series of songs to play are the same repetitive set from the day before. Also, Shuffle still randomly turns off between USB sources, player sources, and entering/existing vehicle, Shuffle "on" is not persistent overnight, or when playing between USB sources, seems random
5. File Directory Listing
Folders should be listed first alphabetically, and then files next alphabetically / Files and folders still intermixed in Folder View / Do not use tag data for sorting anywhere within Folder View
6. Grammatical Articles Used in Alphabetical Listing
Lists are using ‘A’, ‘An’, ‘The’ as alphabetical markers. These prefixes should be ignored for alphabetical sorting. For example, ‘The Beatles’ should be under “B”, not “T”
7. Multi-artist Album / Multi-disc Albums
Multi-artist album tag is not being read, indexed, or displayed for when ID3 Artist tag is not populated / Media Player needs to perform an IF/EXIST query and display album artist if song artist is not populated / ID3 tag DISCNUMBER should be used when sorting a list of files, should group by disk first, then by track
8. Documentation on USB Functionality
• Expected scan times per track/data size – disclose effect of MCU reboot and list rescan triggers
• Documented hard limits to volume size, individual file size, max number of files, ID3 tag fields
• Physical device support/specifications (Flash/SSD, max. USB output power per port/as a pair)
• Supported Tags
• Supported File Formats
• Supported Playback Formats
• Album Art Size/Type Limitations
9. Directory/File Sorting
Directory listing should place folders at the top in alphabetical order, followed by individual files in alphabetical order
