[V9] How to Format USB into 2 Partitions for DashCam and Music [Windows]
Discussion in 'Model 3: User Interface' started by SomeJoe7777, Oct 15, 2018.
  1. DNAPoPo
    DNAPoPo Member
    Orange County/Los Angeles, CA
    Or know the minimum speed rating required for the app.
  2. SpudLime
    SpudLime Active Member
    Leesburg, Va
    Great writeup. The only thing I dont agree with is only needing a 16GB partition. Your math didnt account for when you decide to save some videos. If you tap the icon it saves the files off and if you do this multiple times your 16GB will fill up fast.
    But great writeup!
  3. hamtonp
    hamtonp Member
    Dallas
    Sorry I wasn't more detailed.
    The front driver side USB port I use to just charge my phone.
    The front passenger side USB port has the USB hub plugged in. It is not powered. Well, no external power. I plug two SanDisk 8GB USB 2.0 into the hub. One for the TeslaCam and one for music files. These are just stuff I found in a bin of electronic stuff I have laying around. I don't even know what brand hub it is. It's a generic cheapo 2.0 hub.
    Edit:
    Wanted to mention that the USB drives have not light on them. Just a plain plastic shell. I guess these types use less power.
  4. cbutters
    cbutters Member
    Utah
    Thank you for this writeup. I was having issues with dashcam disappearing randomly and I just followed the guide and will be testing. My only adjustment was that I setup my first partition as size=32768 instead of the 16GB in the tutorial (I plan on saving some of my drives using the button and 32GB still formats using the windows utility) I'm hoping between creating the partition as FAT32 in the windows utility and also converting them to GPT makes the difference.
    Thanks again and I will report back if this works reliably for me.
  5. Knightshade
    Knightshade Well-Known Member
    NC
    The dashcam writes ~1800MB per hour... that's 0.5 MB/s. Literally any USB drive sold as new is way way way faster than you need for that.
    Not really... the entire hour only takes up 1.8 GB... you could save off another 50+ 10 minute clips without running out of room.
  6. cbutters
    cbutters Member
    Utah
    Ok... so the first time I put it in it worked, then I drove it again about 30 minutes later and the dashcam icon had disappeared. But then I drove it a third time and it was back. I've never seen it disappear and then work again without fixing the file system on another computer; so I'm not sure if it was a fluke.... Will continue testing but it is working right now again; just the one fluke the first time I drove it after letting it sit.
  7. StellarRat
    StellarRat Active Member
    Pacific
    #27 StellarRat, Oct 16, 2018
    Following his DISKPART instructions run the CLEAN command AFTER you do SELECT DISK xx . I think that will totally wipe all the partitions and data on the USB key. At that point the procedure should follow his steps. I haven't tried this myself, but CLEAN is supposed to clear the partitions. I know it works on disks 32GB and under, so it might work on larger disks.
  8. TheLocNar
    TheLocNar Member
    Chicago
    I found a free app for Windows 10. First partition of 128GB drive for cam is 32GB and the other partition is for music. Had to use another app to convert a ton of m4a to mp3. Just tossed them onto 2nd partition without any folders. Working good with the usb splitter. Let’s hope it doesn’t get corrupted.
  9. GPinzone
    GPinzone Member
    Ronkonkoma, NY
    I don't want to jinx it, but after converting the drive to GPT, I haven't yet had the dreaded gray "X" that implies filesystem corruption. I haven't remove the drive yet, so I have no idea what's been recorded either.
    If Windows 10's diskpart does not allow you to convert the drive to GPT, try a live CD for gparted. That's how I've been partitioning mine. I tried converting another flash drive on my Windows 10 PC last night and it wouldn't allow me. There are other utilities on Windows that might help if you have a stubborn flash drive like the one I had. I had success with gptgen. (Remember to run the command line as Administrator.)
  10. Galve2000
    Galve2000 Active Member
    NYC
    Thank you.. this is very helpful..
  11. ScubaMal
    ScubaMal Supporting Member
    Bermuda Dunes, CA
    I did do the GPT format first and followed all instructions on a new SanDisk 16gb Cruzer Fit CZ33. Works for a while and after parking I come back to see the "x" in the camera icon. Still getting errors on drive. Running error check and repairing drive fixes it for a while.
  12. insaneoctane
    insaneoctane Active Member
    Southern California
  13. ceekz
    ceekz Member
    Sacramento, CA
    Thank you for this detailed walk through to set up the TESLACAM partition. I'm no IT specialist but I excel at following directions. I didn't set up the other partition for music but might in the future. Can I use a Mac to set up my music if I created the partitions in Windows?
    I have my primary driver phone (iPhone X) set up to charge in the driver's USB port. 4-USB hub in the passenger side with the micro C charger plugged in the tray and a second micro C on a longer cable, dangling so my husband can charge without removing his phone case and the USB drive also in the hub. Looking forward to testing it out!
    This is a good opportunity for Tesla to design the console with more than 2 USB ports that connect to the car network!!!
  14. EVnut
    EVnut DARΞLL
    Davis, CA
    Well, this is great news. And yet... after formatting my whole drive to FAT 32 (with no partition) I'm getting these corruption problems randomly. I'm not sure what the "fix" is supposed to be.
  15. SpudLime
    Leesburg, Va
    @SomeJoe7777
    I dont need two partitions. but I want to format all 128 GB of my SanDisk. Since you said to NOT use the 3rd party utility to go bigger than 32GB. What do you recommend to format a single partition to 128 that "may" fix the corruption issue?
  16. SSonnentag
    SSonnentag Rocket Scientist
    Arizona
    Great writeup. It reminds me again how simple Apple makes things. :D
  17. humbaba
    humbaba sleeping until $7000
    planet earth
    sorry, without a Tesla I can't really help you there.
  18. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    The best recommendation I can muster is to not try to do so. Format it using my instructions in my tutorial post, but skip the DISKPART command to create the 2nd partition (create partition primary align=1024). Then skip the section for formatting the music partition.
    This will result in just one 16GB partition for the DashCam. This is plenty for now, since the DashCam will only store 1 hour of footage from 1 camera. Total size for that is under 2 GB. That also leaves plenty of room to save footage.
    If you really want to format the whole thing as FAT32 and give it a try, then the only partitioner and formatter I would trust to do that correctly would be the GParted live CD.
    I might try this myself just to see what happens.
  19. SpudLime
    Leesburg, Va
    Thanks for the response. I will think about your advice. Let me know how that tool works if you decide to do it.
  20. NJturtlePower
    NJturtlePower Living the Dream, Driving the Future!
    New Jersey
    @SomeJoe7777
    Ok so you had me up to step #9, but I am using a 32gb drive and when the two partitions were created only the TESLACAM one had a drive letter. Did I need to change the numbers used or something?
    The command "create partition primary align=1024" did not work.
    Tried to format/assign drive letter on second partition via disk management format tool with no success. Please Help! :confused:
