To be clear, there are products actually called "USB splitter," and they will probably not work. You need a hub to get data from both drives. The things called splitters are passive devices that pass the data on one female socket, and only pass power on the other, so you can charge a phone, but you can't use both ports for data.
To people still on Windows 7: Install the set of altenative drivers that will allow you to see both partition or try the Lexar tool that MIGHT convert your flash drive from removable to non-removable.
Since following this guide with GPT, I have never gotten the X on the dashcam; however I randomly will sometimes not get the dashcam icon AT ALL and my music USB won't show up. It happens about every 3rd time I drive the car. not sure why this could be. I might try a different drive. (using PNY 128GB currently)
I have the 32G flash drive. I tried to follow the instructions on Windows 7, but it will not allow me to create the second partition. I researched it and it seems that windows 7 thinking USB drive is removable, not allow creating another partition on it. There is work around to change the driver, and I guess Windows 10 and later it is not a problem anymore. I found out it is much easier to do it from command line on Apple Mac, using "diskutil" Xins-MacBook-Proownloads xwang$ diskutil list /dev/disk0 (internal, physical): .... /dev/disk1 (internal, virtual): .... /dev/disk2 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *31.4 GB disk2 1: Microsoft Basic Data TESLA 31.4 GB disk2s1 Xins-MacBook-Proownloads xwang$ sudo diskutil partitionDisk disk2 2 MBR MS-DOS TESLACAM 16G MS-DOS MUSIC R Password: Started partitioning on disk2 Unmounting disk Creating the partition map Waiting for partitions to activate Formatting disk2s1 as MS-DOS (FAT) with name TESLACAM 512 bytes per physical sector /dev/rdisk2s1: 31219472 sectors in 1951217 FAT32 clusters (8192 bytes/cluster) bps=512 spc=16 res=32 nft=2 mid=0xf8 spt=32 hds=255 hid=2 drv=0x80 bsec=31250000 bspf=15244 rdcl=2 infs=1 bkbs=6 Mounting disk Formatting disk2s2 as MS-DOS (FAT) with name MUSIC 512 bytes per physical sector /dev/rdisk2s2: 30062288 sectors in 1878893 FAT32 clusters (8192 bytes/cluster) bps=512 spc=16 res=32 nft=2 mid=0xf8 spt=32 hds=255 hid=31250003 drv=0x80 bsec=30091693 bspf=14679 rdcl=2 infs=1 bkbs=6 Mounting disk Finished partitioning on disk2 /dev/disk2 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: FDisk_partition_scheme *31.4 GB disk2 1: DOS_FAT_32 TESLACAM 16.0 GB disk2s1 2: DOS_FAT_32 MUSIC 15.4 GB disk2s2 This will wipe out everything from the drive and you need to start over by create "TeslaCam" directory on first partition, and copy music files to the second partition.
Windows 7 can be patched to allow all partitions on a removable drive or the USB drive might be able to be modified to appaer as non-removable: Removable USB Flash Drive as Local HDD in Windows 10 / 7 | Windows OS Hub
Followed the instructions. Created 8Gb cam partition. Lasted 2 days ( longer than before). Today I had to lock and unlock the car multiple times and the dashcam broke with the X. Oh well, hopefully they did it next update.
I followed the instructions with a 128GB SanDisk Ultra Fit USB 3.1, creating a 32GB dashcam partition and an 80GB+ music partition. It worked for one drive before the grey X showed up. No magic bullet there.
I realize the original post author intended this to be a general solution for Windows 7 thru 10, but please note: As of Windows 10 "Creators Update" (version 1703, released in April 2017), Windows now has built-in support for multiple partitions on USB flash drives, and you no longer need to use a 3rd-party tool like fat32format. Here are a couple links with examples: Windows 10 Version 1703: USB Stick multi partition support | Born's Tech and Windows World Windows 10 Creators Update allows multiple partitions on a USB drive
Sadly, this solution also only lasted a few days for me before I got the dreaded X earlier and I had to pull our the drive to repair it via Windows. I was urging other people having usb dashcam issues to use this write up in the groups I'm a part o,f which I don't regret because it's still the best one that has lasted longer than my other attempts with different drives, tools, etc. Now that my Raspberry Pi Zero W has arrived I am going to attempt to build a Smart USB drive from a rPI. One of my buddies just confirmed he has been using this solution for one WEEK now with no X issues with his smart usb drive. The only con I see so far is that he has to leave climate control on for 15-20 minutes to allow time for the wireless upload of his Dashcam recordings. The write up is in this GitHub which originated from this Reddit post. From the Prerequisites before you consider it: Assumptions You park in range of your wireless network. Your wireless network is configured with WPA2 PSK access. You'll be archiving your dashcam clips to a Windows machine, and the Windows machine has a stable IP address on your home network. You'll be setting up the Raspberry Pi using a Windows machine.
FWIW I haven't had any issues with the dreaded X, but it might be because I'm using a 120GB M.2 2242 SSD with a USB3.0 to M.2 enclosure/case.
Seems like eventually one will get it sooner or later. I thought I was fine for whole week until today, my 3 got the X. I never unplugged it. My Model X got the X literally on the actual drive after putting in the USB minutes later. I am giving up and will just wait for Tesla to fix it up. I have a blackvue anyways on both cars.
That's correct, Windows 7 won't let you give both partitions letters at the same time. You can do it under Windows 7. It's a bit of a pain, less so if you don't change your audio files very often and can live without seeing them every time. I don't have a Window 7 machine with me now but I did it on Windows 7. I used EaseUS partition master for part of it and had to go back and forth from one partition to another before I had labels on both volumes, but by the time I was done, it worked fine. I left it with a drive letter for only the Teslacam partition, and when I looked at it later with a Mac, both partitions were visible. If I need to look at it with Windows 7 and need to see the audio files, I should be able to use Windows to remove the drive letter and then put one on the other partition.
I've been using it about a week and I've only unplugged a few times. Now that I'm thinking about it, I might have gotten the X before, but I just rebooted the car and it went away. There might be something about unplugging the drive when the X is present that's causing drive corruption. Edit - This is the drive I'm using. ADATA 120GB m.2 2242 SSD (SATA)
Just for a data point.... I was getting the X after about 30 minutes for the first few days of trying. My solution was to take the drive out and reformat it. It would then work again for another ~ 30 files. The last time it happened, I merely deleted all files. I did not format. I *also* plugged it into a USB 3.0 hub along with my music drive. And for four days (record!) it has worked every time. I haven't been brave enough to take it out and look at it. But I have many, many hours of driving on it now. So it should have a whole bunch of files. Does anybody yet know just how it overwrites the files eventually? We keep hearing about this "hour" but with 1-minute files, I can't believe that it clobbers 60 of them at a time. It'll be about 70 hours before mine is full (128 Gig)
