@SomeJoe7777
Ok so you had me up to step #9, but I am using a 32gb drive and when the two partitions were created only the TESLACAM one had a drive letter. Did I need to change the numbers used or something?
The command "create partition primary align=1024" did not work.
Tried to format/assign drive letter on second partition via disk management format tool with no success. Please Help!
Windows 7 doesn’t recognize 2 drive letters for multi-partitioned usb drives. I think that didn’t become available until windows 10. I tried doing this on a windows 7 computer and it errors trying to create a second primary partition. I even tried using a third party app. It’s a no go unless you’re on windows 10 (no go for me anyway)
No kidding.Great writeup. It reminds me again how simple Apple makes things.
select partition 1
format fs=fat32 label="Recording" quick
What error message did you get when you tried the "create partition primary align=1024" command?
@SomeJoe7777
I dont need two partitions. but I want to format all 128 GB of my SanDisk. Since you said to NOT use the 3rd party utility to go bigger than 32GB. What do you recommend to format a single partition to 128 that "may" fix the corruption issue?
@SomeJoe7777 - Why didn't you do the format in DISKPART as well?
Code:select partition 1 format fs=fat32 label="Recording" quick
I don't remember exactly but I am on Win7. Maybe I can just start all over and just make it all one big partition?
That is what I have read...though this process was getting around that some way.
MS has deprecated that software in favor of ntfs. That is the MS way: Their newer stuff is "better" (and you should upgrade) because the old stuff does not work very well anymore ... A person living in the MS universe understands relativity.I know, right? Isn't it ironic that the Mac manages Microsoft's legacy file system better than Microsoft...?
Indeed. Or a *nix. Really, anything these days except WindowsA Mac...
Almost. It was deprecated in favor of exfat. The reasons behind this are somewhat technical, but essentially FAT (including exFAT) are for removable devices and NTFS is for fixed storage. Obviously you can use NTFS with removable and you can use FAT for fixed storage.MS has deprecated that software in favor of ntfs. That is the MS way: Their newer stuff is "better" (and you should upgrade) because the old stuff does not work very well anymore ... A person living in the MS universe understands relativity.
Amazing and detailed write up.
I have to ask a dumb question: is it not possible to use a USB splitter so we can use one USB port for both music and dash-cam?
