Not sure what you're saying here. Gas savings, for me, in the US where gas is cheap, is more than US$5,000 per year. I'd say that's a different order of magnitude than 912€ for FIVE YEARS.
Another expense, paid for under warranty by Tesla, is the need to replace the lead-acid, 12V battery. When the car is off, the 12V battery feeds the thirsty Vampire. Every few hours the main, Li-ion, traction battery connects and recharges the 12V battery, and every few days, the AC connects to charge the traction battery. The constant cycling of the 12V battery means that it must be replaced every year or two, call that 1.5 years. Those batteries are about $150 including installation, or about $100 per year in 12V battery replacement costs.
That's exactly right, but I don't get why the cycling of the 12v leads to an expected life of only 1 year (mine has been replaced at least once, possibly twice by Tesla already). A 12v lead acid battery in an ICE is arguably cycling as much or more than a Model S. An ICE has 12v accessories, including a number of always-on loads, just like the Tesla and certainly cranking over the ICE, then replenishing the battery from the alternator cycles the battery quite a bit.
No other car works the 12V, lead-acid battery as hard as the Model S.
The Model S Vampire is a very thirsty beast!!!
But... but... WHAT exactly is making it such a thirsty beast? My previous Cadillac CTS had an always connected OnStar telematics system, had computers and such that stayed on. Used a fob-based keyless entry system pretty much identical to the Model S (except for the extending handles). I'm not getting what exactly that the Model S has running all the time that is so significantly different than comparable modern ICE vehicles.
That's an important distinction. I drive my car (a lot) daily and it rarely sits more than just overnight. So mine doesn't get a chance to "leak" as much as yours where it is sitting for a long time.
That's actually not true. Every car has the exact same amount of 'vampire drain'. It's the computer system and battery management that uses power. But it needs that amount of power weather you are driving or not. When you don't drive, you can see and measure the losses. When you drive, it;s mixed into the other usage and thus hidden, but the energy is use no matter what.
I believe the car will automatically shut some things down to save power after being left a few days alone.
(snip)
I suppose another option would be to enable constant shore power, such that when plugged in and this feature is enabled, it would keep the DC-DC powered from the wall and thus not cycle the 12v battery at all. In theory, This could even be done with the main contactors still open, to keep the main pack isolated.
That could work, but you'd still get high voltage all over the car (even with the pack isolated.) And it would be quite inefficient. No idea what the no load consumption of the chargers (or the DC-DC converter) is, but I doubt they tried to minimise it.
The whole point of this thread is to understand why and to try to reduce the power consumption at the socket.
I'm going to have to actually test this when I fly out for my next trip, because on my last trip the vampire drain came out to less than 300Wh/day (cars locked, no fobs around, no mobile access while away).
From what I've been able to tell, the biggest offender is the center display. It contains the cellular modem and is always on to varying degrees.
I'm not sure why Tesla doesn't give us the option to completely shut down the car, which would be useful if we were going on a trip, etc. Of course we can disconnect the 12v battery and then there is no vampire drain, but Tesla didn't make this easy.
The MCU has a lot more attached to it than just the ipad screen. It controls a lot of key functions and is responsible for logging so I'm not surprised Tesla doesn't let us disable it easily.
