Vampire drain whilst plugged in?
Discussion in 'Australia & New Zealand' started by joninmelbourne, Nov 17, 2016.
  1. joninmelbourne
    joninmelbourne Solid Black S60 new face
    Melbourne
    I have noticed that when my car is fully charged (406km on my new 60) after a few hours it begins to lose charge even whilst its still plugged in. I got down to 402km and the charging had not started again. Short of unplugging and replugging in, how long until the car tops its self off? Thanks
  2. Blue heaven
    Blue heaven Member
    South West Australia
    Why do you leave it at a state of full charge?
  3. joninmelbourne
    Melbourne
    100% charge on the new 60's is only 80% in reality due to the battery actually being a 75kwh with software limitation. I charge to a full charge (80%) in case of unexpected trips.
  4. rowdy
    rowdy Member
    Australia
    Sounds like the battery pack is balancing. Usually the car needs to drop a couple of % before the charging will begin again.
    Vampire drain is minimal on refresh cars, so once balancing is complete and if it hasn't dropped enough to trigger a charge cycle then it may take days to reach the threshold. Probably easiest just to manually start it again through the app once it appears balancing is complete to get it back up to 100%.
