Ventilated Seats
marsh1n
44
51
Clarksburg, MD
Hi. I have a Late 2016 Model X (AP2.0, MCU1). The car came with ventilated seats that worked well the past few years.
Tesla replaced my drivers seat last week and now the ventilated seat does not do anything. It still works on the passenger seat. Does anyone know if they installed the seat wrong, of does the new seat they installed not come with it? (since new cars don't have this option).
BigMskiman
1,146
692
Pleasanton, CA
I have them, but never looked deep into the plumbing. Maybe you can probe around and see a difference between your two seats.
You could also ask the SC to confirm what they installed. Also, does the MCU displays cooling same both sides?
Fellsteruk
1,040
412
North West, UK
Check the underneath of the seat and make sure none of the connections are loose or removed, there is a blower unit in the seat you should hear it when on if your parked up and you listen.
Does the MCU tell you it’s on and working? Also does the seat heat as normally or is both heat and sucking/ cooling off?
Reactions: Watts_Up
Happy Kappy
2017 Model S P100D and 2017 Model S 90D
Nov 18, 2017
168
47
Milwaukee, WI
They either forgot to connect the harness underneath (check all your plugs) or they forgot to do a redeploy of the new module. Either way it is an easy fix so no need to stress. Call service on it if you don't see wires disconnected (two plugs under carpet...don't touch the yellow one...or the three plugs that go into module). They can often push a redeploy down over wifi.
Reactions: Watts_Up
marsh1n
44
51
Clarksburg, MD
To follow up on this. The SC pushed a software update which fixed the issue, so I'm all good.
Also, I have to say that the overall service experience has gotten much better in the past few months. I like scheduling the appointment and describing the issue through the app. My SC (Rockville, MD) sends multiple texts to me to help with the issue before the actual appointment.
Reactions: Nda721 and bhorn
