Version 17.9.3 - Update 3/11/17
Discussion in 'Model X' started by RR Runabout, Mar 11, 2017.
Tags:
  1. RR Runabout
    RR Runabout Member
    North Carolina
    I received the update last night...
    Key updates:
    Enjoy faster drivign with Autosteer
    Autosteer - from 50 to 55
    Control fan speed more precisely
  2. RR Runabout
    RR Runabout Member
    North Carolina
  3. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    Same here. last night at 8:30 PM
  4. RR Runabout
    RR Runabout Member
    North Carolina
    Well it must have been released in North Carolina - lol
  5. ToddS
    ToddS Member
    Jupiter, FL
    I got it last night as well.
    What were the fan speeds before?
  6. travis010
    travis010 Member
    Orlando
    Mine just updated this morning. It's interesting that my release notes also included information about showing Supercharging costs. I haven't seen anyone else mention that in regards to this update. I'm wondering if it's because I have a new X that doesn't include unlimited supercharging and they omit that note for cars that do have it.
    • Informative x 6
  7. DJ 240V
    DJ 240V Member
    Did you purchase after the "free supercharging for life" window ?
  8. ToddS
    ToddS Member
    Jupiter, FL
    I have free SC and didn't get that part in my notice.
  9. muleferg
    Free SC and no notice.
  10. RR Runabout
    RR Runabout Member
    North Carolina
    Free SC and NO notice for me either...
    .... interesting
  11. Uncle Paul
    Uncle Paul Active Member
    Canyon Lake,CA
    I wonder if those having Free SuperCharger for life will not be charged those fees. Would make sense.
  12. travis010
    travis010 Member
    Orlando
    Yes, my MX75D is a "free 400 kwh per year" version purchased this year.
  13. Allen Peake
    Allen Peake New Member
    Macon, GA
    Free SC and no notice, in GA
  14. sunnyvale
    sunnyvale Member
    Sunnyvale, CA
    I just got update. I got parallel park :D
    Works fine but I am not sure I will use it that much. I wish other park situations are included! :)
  15. ToddS
    ToddS Member
    Jupiter, FL
    I used the park tonight with only ONE car there (and curb as other barrier). I thought it only worked where there were two cars with a slot between them. Pleasantly surprised!!
  16. muleferg
    "I thought it only worked where there were two cars with a slot between them".
    I have tried several times to park with a car not behind. No luck. Only a space between.
  17. BigMskiman
    BigMskiman Member
    Pleasanton
    Interesting find. I guess a curb in front defines like a forward car, so one car and 2 curbs was enough.
    Next, someone will try it on a single parking spot with 3 curbs defining, whowa
  18. rush6410
    rush6410 Member
    Montgomery TX
    Did anyone notice the difference in fan speeds. The notes don't really make much sense to me since they have always had 1 to 11 as fan speeds. I guess I read it as 1 through 3 pushes more air. Hard to tell.
  19. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    I read elsewhere that the update 'enabled speeds 1, 2 and 3 for recirculation mode', which didn't work before because the air flow was too low for the coils (meaning for air conditioning?). It's not too clear, as you say.
    Also, for the Supercharging 'tally', I'd not seen those notes before (since as was said, it's only for after January 15th builds). Does it mean that it does give you a constantly updated total of what you are using (like a gas pump, lol), or only when you are done? It says 'will be updated shortly after you are completed', but that could mean the final total of what you use in all.
  20. ToddS
    ToddS Member
    Jupiter, FL
    Yes, the fan is only when recirculating.
    As for the SC (although I have free SC), I think it tries to estimate the total as you begin, but then at the end gives you the definitive amount. Hopefully those numbers are pretty close.
