Tesla disputes the UMC / fire connection, but it did change the software after that fire and fluctuations now cause the car to dial down the amps much more readily than in the past, and they seem to keep tinkering with it. That's qwk's point in starting this thread, I think. I've also read here about, and seen pictures of, burned or melted UMC's 14-50 adapter whereas the plug and socket connected to my HPWC don't get the least bit warm:
Bingo!
Not only did Tesla implement this in the firmware, they keep messing with it. That is my main gripe. One firmware version everything is fine, the next the car can't charge. Tesla keeps messing with firmware, and that's understandable, but things that work great really don't need changed. Regen is another good example.
Living so far from a Service Center, all I wanted was an option to stay on a very stable firmware version, so I could use the car without unexpected problems. It is our family's only vehicle. TO ME, the constant over the air updates are the worst thing about the car, by far. They create too many bugs while not adding huge changes(naming my car doesn't help me one bit). Updates such as individual tire pressure readouts, valet mode etc. would be different, and are possibly worth taking a risk for. I usually don't install the updates, and just ignore the update clock, but many times the simple fact the the car is pinged with a new update introduces a bug. This time it was the car not going to sleep most nights, so I figured I would chance it, and see if loading the update fixed it. It did, but the charging problem surfaced(I did try to reboot screens for the insomnia problem).
Another problem I should point out is the fact that there is no ATT 3G here, so engineers can't even pull logs and possibly fix the issue remotely. I do have WiFi at the office, so that helps, but the car only connects when driven on the lawn next to the router. I should note that all other devices like iPad, iPhone etc. can reach WiFi across the street. Anyway, I'm sure it's easy to live a few miles away from a SC and many Superchargers in California, and think that I'm just a complainer, but it's a totally different world out here. It's like the Wild West.
- - - Updated - - -
My question is still unanswered-- why do you insist this is a firmware issue and it wouldn't have happened if you hadn't updated the firmware? If this is a firmware issue, don't you think there would be a significant number of reports of this happening all of the sudden after the update? Until Tesla finds the source of your problem, I think it would be best to keep an open http://www.teslamotorsclub.com/showthread.php/42243-FW-6-1-turned-my-car-into-useless-junk-%28charging-problems%29http://www.teslamotorsclub.com/showthread.php/42243-FW-6-1-turned-my-car-into-useless-junk-%28charging-problems%29mind about other possible causes. What if they found the charging port was bad and a new one solved your problems?
Prior to FW 5.8.4, the car had a voltage threshold that it would not charge under(around 190V for 240V or 208V service), and it allowed a peak of something like 6mA through the ground before one would get the red chargeports ring, and a no go on charging.
After FW 5.8.4, minimal fluctuations in the Voltage cause the dial back to 30A, or even stopped charging. This changes constantly, so one day you are fine, the next SOL.
The same night after experiencing the problems which birthed this thread, the car charged fine at 40A for three hours. I of course wasn't under pressure to the car charged by a certain time. Murphy's law pretty much guarantees that these problems show up when you are on a tight schedule or at an RV park. That's just the way it is. Imagine plugging in to a 14-50 at an RV park, and taking a nice 1-2 mile walk to get a bite to eat. While eating or even walking there, you check the app, and bam the car stopped charging because of a one time 6V fluctuation at the RV park(these voltage fluctuations happens all the time at RV parks). Now you have to either pray like hell the car starts charging again on it's own, or walk back all pissed off and unplug/replug. Remember, this was not a worry for about the first 2 years of ownership. How would you feel?
- - - Updated - - -
I live really close to a generation plant. I can charge at 40A just fine except in the presence of a misbehaving appliance, overloaded transformer, bad wiring, or a bad component in the car.
No other common appliance draws 40A continuous current for hours upon end while being connected via cord-and-plug. For most homes, the Tesla is the largest electrical load in terms of kWh that most owners' homes will ever see.
Congratulations, your car works fine with this FW. You have no worries. Mine on the other hand all of a sudden doesn't, and I can't and won't live with it, hence this thread.
