Zetopan
I picked this one up for about $100 new (it's been a while, so don't remember exactly). Smaller than a utility meter, easier to read too (digital readout of KWh). You just feed the wires through it (no cutting, only a couple of screws that tap the wire, so yes, breaker must be off during installation).
There is an even cheaper solution available that monitors more than just the total KWH used - at least for those inclined to build things. I installed a $12 electronic measuring device that monitors the voltage, current, KW (kilowatts, power), KWH (kilowatt-hours, energy), and cumulative time. This model displayes those readings one at a time while there are also other models available that display all of the measurements at once (but using a much smaller font). A housing is also required (I used a metal and plastic box that I had available) and this device is intended for indoor use only, unlike the standard utility company KWH meters. Of course the housing could completely enclose this meter (similar to what whitx did with his meter), in which case it could be used outdoors. Mine is mounted inside the garage so I did not need a full covering enclosure.
5 in 1 AC 100A Digital Electrical Combo Panel Meter Volt Amp kWh Watt Work time | eBay
