That sounds like a load of bees under the car.It's not that bad. His car was probably colder.
I wish mine was anywhere near that quiet.That sounds like a load of bees under the car.
Noise levels may be down to how well the pump is bolted down (if it is the pump). Why dont you do a service and stick the vid in as an attachment so they can take a look at it?
I have exactly the same thing on my 2021 MiC LR. Booked a service, gave them the video, they recreated the noise and said it’s expected and is the heat pump.
I asked why aren’t all heat pump models making the noise. They said they didn’t know. I complained that I could hear it from inside my house. They said the noise is “within tolerance”. Not overly happy.
I’d say you should book a service appointment anyway. If there are enough instances of people complaining about it then they’ll be more likely to do something about it.Wow....well that is disappointing for sure.
Also, not sure I buy it....as i'm sure you will agree its really bloody loud but i've never heard it when the car is "running" Even when i'm parked up somewhere after a drive with the climate control still on.
Surely the heat pump would make the noise at other times too, not just when the car is cold and your preheating the cabin?
The heat pump is in the front. The whining coming from the rear is definitely not the heat pump.Also just for clarity, this is what they wrote about the issue in my service invoice:
Carried out investigation into customer concern. Checked for alerts present at time of fault and no alerts were present relating to customer concern.
Carried out thermal test and found heat pump operation normal, noise caused from heat pump is due to compressor RPM ramping up and will be louder when revolutions of increase (heat pump working harder) This is especially noticeable when pre conditioning.
This creates no cause for concern and upon testing no issue can be found with the heat pump system. If you hear a different noise than supplied in the video then please do raise this as a concern however buzzing from the heat pump is of normal operation.
That’s what I said to them but the guy just shrugged his shoulders and said “well it is the heat pump”The heat pump is in the front. The whining coming from the rear is definitely not the heat pump.
How do you mean?However, could there be resonance going on here.
How do you mean?
