Yeah, mine does something goofy like that too and it’s when you go to reset it does something different. I think mine blink when turn it back on if arc fault. And don’t blink if load tripped it.Thanks! I did not know that. I looked up the data sheet and you have to turn the breaker off, hold down the test button, and then turn the breaker back on. If it trips immediately it was a ground fault, if it trips in 2 seconds it was an arc fault, and if it trips in 5 seconds it is either no fault, a thermal overload, or a short circuit. I'll have to try that.
