Vibration in steering wheel?
Discussion in 'Model X: Driving Dynamics' started by modelx007, Mar 5, 2017.
  1. modelx007
    modelx007 Member
    boca raton, fl
    Anyone notice your steering wheel really vibrates at highway speeds? I only noticed this when it was in for service a few times for the shudder issue. From researching it seems man up on the model S had had a steering wheel vibration but haven't seen any discussions for the X. Apparently the main office has no solution for my problem and nothing can be done. I've had he front tires replaced as well. It is really annoying to have to always use AP 1 on the highway because I don't like feeling the vibrations and it isn't road transfer either. My wife says it is worse now and this is what happens when one complains. 120k+ car and I am sorry.
    Anyone else have vibrations?
  2. OzSimon
    OzSimon Member
    Gold Coast Australia
    Yes, my steering wheel and brake pedal vibrate when aircon fan above 5. Hope to get it fixed soon!
  3. vandacca
    vandacca ReActive Member
    Hamilton
    I had this same problem. Turning off "Lane Assist" fixed it for me. :)
  4. davidc18
    davidc18 Active Member
    Ft. Lauderdale
    Several visits to SC - swapped out 19s for 21s, 3 alignments, retorque all suspension points all with zero improvement. I finally gave up and started the lemon law paperwork. This one is going back to Tesla.
    • Informative x 2
  5. davidc18
    Ft. Lauderdale
    They also replaced the front brake rotors. No improvement.
  6. goneskiian
    goneskiian Active Member
    Bellevue WA
    Vibration in the steering wheel can also be caused by an improperly balanced front wheel/tire combo. If the vibration is in the seat and you feel it through your arse, it's most likely the rear wheels that need it. These are especially noticeable at highway speeds.
  7. nnick01
    nnick01 Member
    Bay Area, CA
    I would not accept this problem. They would have to fix it or replace the vehicle.
  8. xkwizit
    xkwizit Member
    Folsom, CA, United States
    I noticed this early on and wheel realignment took care of it.
  9. MS16
    MS16 Member
    Calif
    Two wheel alignments by the Service Center. Still have vibration in the steering wheel.
    My vibration problem remains unresolved and the Service Center has little interest in further troubleshooting.
  10. modelx007
    modelx007 Member
    boca raton, fl
    It really is a perplexing problem. My X is in the 3XXX vin range. My X has been in the service center many times from delivery May 2016 but accepted the other issues from Falcon doors to air noise in windows, door lock failure to charge port replacements.. However the latest started around Nov 2016 with the shudder on acceleration. They replaced the front axels etc... the shudder was better but not completely gone and unfortunately after going back in many times for it, the vibration in the steering wheel became very apparent. They replaced the front tires and that still didn't solve the problem. I just got it back a few days ago and the problem is probably worse. I'm told that no fix exists and other X's have this so HQ says "in specs". I tested a demo X on local street surface and felt a vibration so that is how they concluded it is with them all. My vibration is much worse on the highway at highway speeds and unfortunately didn't take the demo on the highway to see if the vibration was as bad as mine. When I'm holding the steering wheel it seems like I can feel the vibration rotate through the steering wheel. I have to drive with AP 1 on the highway or else it would drive my crazy. Out of everything I've had wrong with my X, the vibration is a real problem and very frustrating as apparently I can do nothing about it. I love my X but now hate driving it (mind boggling to think like that).
    Also after my last pickup a few days ago, the shudder problem now seems to be increasing! (Should have never brought it in (wrong thinking I know but that seems to happen a lot).
    I also own a model S (2016) and love it. It had very little to none vibration that I wouldn't complain about, so I know what "vibration" feels like.
    So the question is, perhaps everyone has vibration in the steering wheel and you aren't sensitive and perhaps mine got worse with all the times I brought it in with them trying to solve it and they really have no idea how to solve it.
    I just wish I could find someone who would acknowledge the problem and give a solution as solutions have to exist for all problems.
  11. modelx007
    modelx007 Member
    boca raton, fl
    Unfortunately, it isn't in the seat. See my previous post...
  12. MS16
    MS16 Member
    Calif
    That's basically the response I'm getting as well, in so many words 'we can't fix it, others have it, therefore it must be within specs'
  13. goneskiian
    Bellevue WA
    I got that from your first post actually. I was simply differentiating the difference in feel between front wheel imbalance and rear wheel imbalance. It sounds downright terrible. Sorry they can't seem to find a fix. Just curious though if you've asked them to rebalance the wheels. I'm sure you're aware but alignments are not the same.
  14. Navsarin
    Navsarin S100D Red Rocket
    Canada
    March 2016 delivered S90D...pre facelift. Never had any vibration issues for 14 months until just recently.
    I've had alignment done 2x, tires balanced 3x and even purchased 2 brand new 21" contact contisport 5's on the front. At speeds from 70kph and upwards it feels like a slight vibration and gets progressively worst as one gets above 110-120kph.starts to feel like a front suspension issue, bearings etc. Checked at SC and none of those issues. Getting quite annoying now having to drive the car and wince every time I go over 70.
    I'm at a loss...other than perhaps the wheels themselves maybe the culprit? Warped? Didn't detect any hopping. And for brand new and balanced tires on the front, surprised to feel any vibration at all.
    My kids also tell me they can feel more 'bumpiness' at highway speeds...as if the rear are also out. But again all 4 tires at 0.00/0.00 balanced perfectly.
    Love and hate my Tesla right now. :(
  15. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ Fritterer and waster of hours in an off hand wayer
    Portland, Oregon
    At least it's still under warranty. Can't the service center technicians feel it? I would think it would be up to them to figure it out or replace your whole suspension if need be.
  16. tangerine
    tangerine Member
    SF Bay Area
    I believe I have a bit of this shudder/vibration also.
    At first I thought it was road transfer (like from the bumps on the road at highway speeds to alert you when changing lanes unexpectedly). However I tested the road transfer bumps and it felt like nothing coming through the steering wheel and column.
    60ish miles into a new Model X, and it already spent a week at the SC a couple of days after I took delivery for a non-working AC...not sure what to do, possibly live with it for now?
  17. Navsarin
    Canada
    It's in service today. They are retesting and balancing all tires...road test...moving front to back...road test...trying an extra set of 21's onsite ..road test. Essentially to find out if it's one or more specific wheels or tires causing this. Failing which they will diagnose cool suspension and tie rods, axle, control arms.
  18. Navsarin
    Canada
    Ok after testing, they finally removed tires off the rims and spun them independently. One rim on front passenger was warped and small dent on inner side...likely a pothole. Phew! At least not suspension! For now moved it to the rear and I guess looking for 1 21" turbine now!!
  19. Navsarin
    Canada
    Update: It was more than just a tire. Ended up replacing both my front half shafts, new engine mounts, new front bearings...they kept the car for 10 days. Got it back and still has a very slight vibration with pressure on the steering at 50mph and higher so at this point still at a loss. But acceptable.
    • Informative x 4
  20. Navsarin
    Canada
    After a few days of driving there is still a slight noticeable vibration but more from the rear I'd say. And more so 50mph and up. Could be rear drive unit as the differential is tied into it and creates a hum or a slight vibration when not in perfect order.
    Again all wheels straight, balanced and all tires same. Hmmm....
