Video 15' 85D Steering Click
Discussion in 'Model S' started by blee321, Jun 23, 2016.
Tags:
  1. blee321
    blee321 Member
    Stony Brook NY
    Just this week my 85D developed a awful steering click. Does anyone know what is causing this?
    Thanks in advance.
  2. sorka
    sorka Well-Known Member
    Merced, CA
    Wow. That sounds bad. Is this a common problem?
  3. mikeash
    mikeash Active Member
    Fairfax, VA, USA
    This sounds like (but is much worse than) a click I had. Mine only manifested when turning to near full lock and only in one direction (I forget which now). I didn't pay much attention to it, but eventually I had it at the service center for something else and they noticed the click and replaced some bushings as part of a service bulletin, which fixed it.
    I would definitely have your service center look at it. I'm sure they'll be able to get it fixed right up for you.
  4. SherSlick
    SherSlick Member
    Denver, CO
    My best guess is a loose/busted tie rod end. Could also be a loose/busted ball joint.
    Also possible is a broken strut bearing.
  5. blee321
    blee321 Member
    Stony Brook NY
    apparently there is a service bulletin out about this.... not dangerous something needs tightening... blah blah...
    got an apt 1 month from now... :/
  6. Newscutter
    Newscutter Member
    Wexford, Pennsylvania, United States
    I had the same click-- EXACTLY. Ranger came and slid some washers on the rack, retorqued and it's all gone.
    As I understand it, the click *CAN* reoccur but I have thus far not had it in any repeatable fashion.
  7. fsedano
    fsedano New Member
    Le mont sur Lausanne
    I have exactly same issue:
    I was told it's a known issue, they 'fixed' it.. but noise stayed the same. Then they said there's a second modification that needs to be done on D models. I'm taking the car tomorrow again to have it fixed, they said it's not a safety issue.
  8. vlad22
    vlad22 New Member
    Edmonton Alberta Canada
    The issue is the two main bolts that mount the steering rack to the body of the car. Mine were first removed, cleaned and retightened but the noise came back. They replaced with two new bolts and the sound has never returned. About a 20 minute fix.
  9. Model S M.D.
    Model S M.D. Ludicrous Radiologist
    Houston, TX
    @blee321
    I had a similar issue. Took it to the SC and they had a listen and immediately diagnosed it as a known issue with a service bulletin. They fixed it and the loud creaking noise went away. There are a few clicking noises as I get to the end of the turning radius, but I am told this is normal and present on every vehicle.
  10. blee321
    blee321 Member
    Stony Brook NY
    Hi all,
    I'd like to update the status of the creaking.
    It was repaired!!
    I've attached a copy of the invoice.
    Hopefully this will help someone in the future.
  11. Dynastar
    Dynastar Member
    Billings, MT
    I'd be worried about pooping noises too!
