VIDEO - Malfunctioning Door Handle
Discussion in 'Model S' started by SSonnentag, Jan 14, 2020.
  1. SSonnentag
    SSonnentag Rocket Scientist
    Arizona
    Does anyone know if there is anything I can do to fix this, short of scheduling a service appointment?
    12/2017 Model S, out of warranty.
  2. EV-Fixme
    EV-Fixme Supporting Member
    Orange County, CA
    Strange, have not seen this. Does it ever retract all the way in? Does it act up like this when it rains or wet? There is a switch that gets pressed when handle retracts to stop the motor. I would suspect there is a issue with that or the controller?
    You can replace with any color door handle since you can swap the painted part with yours.
    Rich Rebuild has a great video for removing the handle which I used for the first time I fixed one.
  3. SSonnentag
    Arizona
    It retracts all the way in like normal when the doors handles all retract, but when it extends it does this business. The door cannot be opened using the handle. There is no play like normal when the handle is extended it is completely rigid.
    no rain for a couple of weeks. I did wash the car recently, but it was nothing out of the ordinary.
  4. EV-Fixme
    Orange County, CA
    The it's proably a breaking paddle gear. And soon will be total broken, search for paddle gear and get a few on hand if you plan to fix it yourself (you will want to have spare for the rest of the door. and at $2 a piece I just buy 10...)
  5. DKPowers
    DKPowers Member
    Finland
    The motor sounds weird. I'd say that is the problem and if so, only a new handle will help. Fortunately the 3rd generation handles are supposed to be much better.
  6. SSonnentag
    Arizona
    I got the following reply from my inquiry to Electrified Garage:
  7. SSonnentag
    Arizona
    When were the 3rd gen door handles introduced?
  8. DKPowers
    DKPowers Member
    Finland
    I'm not sure but I think around end of 2018 or early 2019.
  9. smilepak
    smilepak Active Member
    Eastvale, CA
    My handle had issue and mobile ranger replaced under goodwill. I was out of warranty. So it depends.
