Due to my hubris, I had an Autopilot accident when 'auto-steer' failed to come on after a double-tap. TACC worked but I didn't notice the blue lines were gone so I let the car drive over a curb. No visible body damage and the air bags did not deploy but the passenger side, wheel rims and tires, will have to be replaced. The tires are still holding air but the car remains parked until repaired.
Tesla advised:
I don't think they understood my original note. Regardless, I have a plan:
I have a legacy dash cam set up in the cabin to record video; audio; GPS metrics, and; 3-axis acceleration. Here is the narrative under the public YouTube:
Given moderator sensitivity about some subjects, I recommend Google my YouTube channel to see the video.
Bob Wilson
Tesla advised:
Thank you for contacting Tesla in regards to your tires.
So we recommend you find a local tire shop to repair this. There is a foam insert on the inside of the tires that they need to cut out in order to patch your tires.
Please do this at your convenience.
Best regards
Best regards
- Photos to get estimates at Costco and Firestone - discuss lead times and their ability and willingness to do Model 3 alignment.
- Estimate from Tire Rack for wheels and tires. Replace tires as I have the jack adapters.
Video recorded at 2 frames/second so playback is hurried. Adjust playback speed to slow; "SPACE" halts; "," backup one frame, and "." forwards one frame. Use embedded time stamps:
23:52:29 (hh:mm:ss) - distant car hits brake lights at green traffic light
23:52:33 - hit brakes to slow approach which turns off Autopilot
23:52:42 - lead car turns so reach up to 'double-tap' back into Autopilot
23:52:49 - I failed to notice a Auto-steer down, traffic aware cruise control is OK
23:52:51 - "Fred" on, I failed to notice close approach to curb
23:53:00 - Car steered to curb where bad things happened
23:53:01 - Significant impact, no air bags but rim and likely tire damage
The rest are my lame attempts to figure out what broke and drive home.
Bob Wilson
