View Front of Car video while parking
wayfair87
New Member
May 6, 2019
2
0
Seattle, WA
Hello! We have the world's tiniest garage and I've hit our old car on the side of it multiple times while pulling in. I would like to stop doing that with the Tesla, and I'm wondering if there is any way to view video from the camera pointing at the front of the car while parking? I can't find any easy way, but unfortunately the garage is so tight that it tells you to "Stop" because you're too close to the sides well before you're actually going to hit anything. Also open to other suggestions!
dsvick
Closed
Jun 10, 2016
2,198
2,214
NE Ohio
... I'm wondering if there is any way to view video from the camera pointing at the front of the car while parking?
The forward facing cameras are located behind the rearview mirror so the view from them wouldn't help you much. A mirror or a ball on a string are probably your best bets.
Reactions: VQTRVA
WilliamG
3,024
2,919
Seattle, WA
Save your money and get one of these.... it's awesome because it works with Summon, it will stop when it feels the bump of the tire and you'll know when to stop :) I've been using them for years and have saved my cars from lots of bump damage https://www.amazon.com/Camco-AccuPa...ords=accupark&qid=1557243288&s=gateway&sr=8-1
If you have a tight garage that won’t help. My garage is 192” long and the car is 185” long. I believe the Model 3 will only summon into a garage up to 8” clearance.
VQTRVA
451
476
CVA
Tennis ball hanging from ceiling vote here.
Where technology is not optimal
Reactions: Deslah
akirtes
5
2
Cary
Here is what I do: I drive into the garage with the rear Camera on. On the garage floor, I have a blue tape stuck on the floor at the right spot. As soon as I see that tape in the Camera, I stop driving
Reactions: SMAlset
BluestarE3
4,083
5,154
Norcal
I just place a Post-It note on the wall of the garage. When I pull in, I look out the passenger window and when the outside mirror just clears the Post-It, I know I have to stop. No-tech and failsafe solution (unless someone moves the Post-It).
GT18
New Member
May 11, 2019
Georgia
I use a marker on the side of garage, when I look left and I’m lined up with it I stop. Gives enough room to get around rear and plug it in without hitting anything in front of me.
KenC
3,290
3,005
Maine
Paint lines on floor designating sides, then reverse into garage, using the reverse camera. Line up lines on cam with lines on floor.
