That's the Sentry icon. This is the dashcam icon:Right, yes, my post wasn't clear, the icon with the red dot disappears once the car in moving. Do you see the same behaviour?
Just confirmed my suspicion. Installing the TapTess Gen 2 wireless charger pad using the provided USB splitter disables the Dash Cam. I disconnected one side of the TapTess and plugged the Samsung T5 SSD directly back into the USB port and Dash Cam icon you kindly provided came back (I thought this was how it used to work but forgot). That's not good news that using the TapTess wireless charging pad disables the Dash Cam. I'll report this to TapTess as well as relevant forums. Thank you for helping me work out what was going on.
When I still used my Taptes (gen 1) pad, the dashcam worked in that configuration. But I didn't use an SSD (just a Micro SD card with USB adapter). I suspect it simply consumes too much power for the USB port to be able to supply both the pad and the SSD.Just confirmed my suspicion. Installing the TapTess Gen 2 wireless charger pad using the provided USB splitter disables the Dash Cam. I disconnected one side of the TapTess and plugged the Samsung SSD back directly into the USB port and Dash Cam icon you kindly provided came back (I thought this was how it used to work but forgot). That's not good news that using the TapTess wireless charging pad disables the Dash Cam. I'll report this to TapTess as well as relevant forums. Thank you for helping me work out what was going on.
Right, could be an issue specifically when using the Samsung T5 SSD (which may apply to all SSD's) which I believe do require more power. Anyone else using a Samsung T5 SSD (or any SSD) experiencing this issue?When I still used my Taptes (gen 1) pad, the dashcam worked in that configuration. But I didn't use an SSD. I suspect it simply consumes too much power for the USB port to be able to supply both the pad and the SSD.
Ok after doing more research. The major downside of this device is it doesn't work with other drives and it only has 64 or 128gb options for its internal drive.
At the suggestion of another Taptes wireless charge pad / Samsung T5 user, I tried swapping the splitter cable inputs (he mentioned they can be unreliable) and now the Dash Cam icon is back and both the Taptess wireless charger and the Dash Cam along with Sentry Mode seems to be working. I’ll keep checking over the next few days to make sure the Dash Cam icon continues to show up on display. Let me know how you get in with your set up.I'm getting a T5 SSD tomorrow and I'll see what my results are when plugging it in.. Tesla Raj on youtube just posted what I think is going to be the best way to access the dash cam footage until Tesla can get it working internally. There's a product called Roadie (sp) that you can buy that lets you wirelessly access the ssd without having to disconnect the drive from the car.
Roadie for Tesla
As it turns out, the issue I was having with the Taptes wireless charger and the Samsung T5 and the Dash Cam was my error on the install. I did read the Taptes manual but the instructions didn't click that the provided thinner USB splitter cable is for the power only and the thicker one is for Dash Cam, Music and USB Charging (provides Sync capabilities which the thinner power cable does not). There is nothing wrong with the Taptes Gen 2 Wireless charging Pad and it will work fine with the Samsung T5 if you plug it in to the thicker cable. Sorry for wasting everyone's time .At the suggestion of another Taptes wireless charge pad / Samsung T5 user, I tried swapping the splitter cable inputs (he mentioned they can be unreliable) and now the Dash Cam icon is back and both the Taptess wireless charger and the Dash Cam along with Sentry Mode seems to be working. I’ll keep checking over the next few days to make sure the Dash Cam icon continues to show up on display. Let me know how you get in with your set up.
Hi-
Creator of the Roadie here. The device is a raspberry pi zero which doesn’t allow external drives to be connected.
If I offered larger drives would that work? 256 or 512?
Also if there’s a way to clean up the device when you arrive home would it be ok to use the 64 or 128?
Overall, id like to understand why folks use very large disks?
thanks for the help!
Jake
64GB would fill up rather quickly since sentry mode activates quite frequently in crowded parking areas. 512 would be much better. I think people would like the convenience of not having to worry about storage being full too often. I personally prefer to delete my videos manually rather than letting them get overwritten. Anyways this seems like a product that has great potential. Thank you!Hi-
Jake
Hi-
Jake
So can you do 256 or 512?The 64GB holds about 10 hours of video so unless you want to save every second that would hold quite a bit of sentry events and saved videos.
the card is a class 10 micro sd rated for video and in the months we’ve been beta testing with folks there’s been no issues.
