Thanks! So most likely they were only going forward for this to test the thrust and performance of the new engine.
Appears in the last test they did some climb, reaching 71,000 feet or 13 miles (from the 46k ft./8.7 mile drop alt. from SS1) and mach 1.4.
SpaceShipTwo sets new altitude and speed records
So the previous SS2 test they say the engines ran for 20 seconds, "The SS2 rocket engine fired for 20 seconds, pushing the suborbital spacecraft to an altitude of 71,000 ft (18 km) and a top speed over Mach 1.4, both of which were new records for SS2."
In the test that failed they said it failed after 2 minutes, counting from the point being dropped from WK2.
So to me it seems like the new engine ran longer. I don't see SS2 falling to the earth for 100 seconds before they fire off the rocket engine to be at the same duration of run-time for the engine as compared to the earlier test. So that alone has more stress on everything, the motor, its components/delivery system, and the tail.
All that black soot in the pic was one issue they were trying to resolve with the new plastic (petroleum) based fueled rocket motor. The previous one was rubber. The new plastic based fuel offered better performance and more thrust.
Here's a video of the tail section, it appears they did rotate it and shoot up in a 90 degree angle after the drop from the test before:
SpaceShipTwo's Intense Rocket Ride - Tail View and Cockpit Recording | Video
In the video following the one in the link above, a person talks about the accident, he stated that the engine after the drop didn't perform properly, it fired then shut down then fired again. They called it a hard restart when it refired. They said the ship broke apart without any explosion.
