1NJ85D
VT 0.50.07
VT 0.50.07 feels more responsive and stable than .06!
Thank you, thank you, thank you!!
Are you asking about a notification when there is an update pending or when an update has just occurred? There's not enough information available form the APIs to implement the former. The latter is possible, but there hasn't been any interest in that to date.Quick question, is there any way to get a notification of a software update? I have an Android phone which doesn't have Tesla notifications so it would be nice if Visible Tesla could let me know.
Thanks for a great app!
Thank you. Even if Tesla decides to support third party apps, I have no plans to monetize VisibleTesla. It's always been done for fun.Jpasqua,
First and foremost, thank you so much for Visible Tesla. I hope that, some day, Tesla Motors will officially support third-party apps and you will be able to monetize your effort. I would gladly pay for it. In the meantime, I would love the following additional features:
Since turning on the AC is directly supported by Tesla's REST service, you can invoke it yourself without involving VT. Are there reasons it would be more useful/easy to do this via VT than going directly to Tesla's API?1) HTTP command to turn on climate control
Are you asking for the time remaining in a trip that has been entered into NAV and is currently underway? If so, I don't think there is a way to get to this information in Tesla's APIs. If I missed it, someone please let me know.2) Additional variables (to be used in a custom web page) containing TRIP time, miles and energy (KWh)
3) Expose additional information already known to VT in the form of variables (again, to be used in a custom web page). Some examples: Car Locked/Unlocked, HVAC On/Off, Internal and External Temp and Climate Control Set Point, and so forth
I would like to refactor VT so that the UI is decoupled from the backend. That would allow it to be run as a service and display the UI on any device including iOS. This is not likely to ever happen for a couple of reasons, primary among which are:4) Ability to run VT on Windows as a service
5) Ability to run VT on iOS (either as a "thick" or "thin" app). I believe that would mean removing the dependency on Java.
Hi 1NJ85D,
Then my question:
I tried to export the gps-data but don't get prompted where to save the kml-file. Hope someone can help me soon because i need the tracking data of next weekend.
It would be helpful if you indicated which OS you're running VT in, and which version of VT.
Any chance it would be possible to have VT continue trying to connect to the car if it doesn't seem to be available? Mine times out with the "Unable to communicate with your Tesla" message. Basically everywhere my car is usually parked has no cell or WiFi reception, so coordinating the opening of VT with one of the times the car is out and about can be tricky since I'm by definition away from my desk.
Still no luck with the Graphs tab not working. I've tried all the loading options in preferences. I guess I have to wipe out my data files and start over?
- - - Reply to FVO - - -
If you've selected a trip and the button is not gray and you press it without seeing a dialog box pop up, then there is a problem. In this case I suggest that you upgrade to 0.50.07 and try again. If it doesn't work, please check the log file and send it me if you can. For details on where to find the log file, check the Troubleshooting section of the FAQ.
- - - Reply to Gizmotoy - - -
Joe
On my PC running Win7 Ultimate 64 bit the, "Make PC Shortcut" script does not work. I have to manually create a shortcut from the icon and then edit the shortcut properties to point to the vtrunner.bat file to get VT to work. Not a big deal but just FYI. Great program. Wish there was an android version.
Love this program!
I run VisibleTesla 0.50.07 on an iMac in Norway. We use Kilometers an meters as units, not miles.
VT shovs km on all tabs except trips tab. My trips come up with miles not km. Same happens when i use map it. When i hover my mouse pointer over part of my trip graph it shows miles, mph and feet, not km, km/t and meters as expected.
Range in lower right corner under my trips is in km as it should.
Any idea hov to solve this? Is it a software glitch ?
