Vision Only Autopilot Not Calibrating
LoganNolag
104
96
I've driven my vision only Model Y for about 150 miles so far over the last week and it hasn't finished calibrating yet. The blue ring made it almost all the way around after about 20 miles but it got stuck at probably 95% - 98% and stayed there for the next 100.
I have an appointment to install the garage door opener on the 17th so when I contacted Tesla they said it wasn't normal and they said they would check it out then.
After reading some other threads I figured I would try and solve it myself so I soft reset the car and restarted the calibration now after about 30 miles it is back to about 95% - 98% and seems to be stuck again.
I have yet to take it on the highway could that be the cause of the issue? Although I have driven it on many large multilane roads. Does anyone have any suggestions?
TresLA
146
171
L.A.
Do you have a longer trip to drive coming up soon? Maybe try hard rebooting (the one where you park for a couple hours at least and make sure sentry mode is off and no 3rd party apps waking up the car), then restarting calibration and going on a longer drive?
LoganNolag
104
96
No plans for a long drive anytime soon.
buyleonard
68
85
Oregon
It will only calibrate with well defined lane lines on both sides of the car. Driving home from picking my car up, it calibrated to about 95%, and then stopped because the road at that point was 4 lane divided road, which meant neither lane on my side had lines on both sides of the lane. I had to go find a road with good lane markers on both sides before it would finish.
LoganNolag
104
96
Yeah that's what I heard. I drove for about 15 miles on a 6 lane divided road with ok lines but I guess it could be that that isn't good enough. I think I might have to take it on the highway but I've heard from some people that side roads are actually better.
buyleonard
68
85
Oregon
I actually finished the calibration on the freeway. Drove south a few miles, took the exit, and the got back on going north. About 5 miles each way, then it finished.
danimal99
New Member
Apr 21, 2021
3
0
Austin
I had the same issue with mine last week. It ended up taking 234 miles, but I reset calibration at 150 with it being stuck around 98%. So after reset it was 84 miles.
I don’t think I needed to do the reset at all however. I had mainly been driving in suburbs and short stretches on a few bigger roadways. But after one night reading on the forums that you need to drive on a long, well-marked, straight road like a major highway or interstate I got up the next morning to do just that. I planned to drive to a different city and supercharge there, but I was barely out of my city on the interstate when AutoPilot started working.
LoganNolag
104
96
Took it on the highway this morning and it finished right away after maybe 5 miles. Looks like the vision only system really needs some highway driving to finish. Seems to work really well although I did get a side pillar camera obscured notice a couple of times on my drive back. I wonder if maybe there is something wrong with the camera and that is what was causing the delay.
ahoen117
80
156
Western NC
So, when I first picked up my car I had similar obstructed popups for my passenger side B pillar camera, mainly in low light, rain, or fog. As turned out they left the protective plastic on that pillar when I took delivery. It sounds silly, but may be worth checking.
LoganNolag
104
96
I'll check it out tomorrow but I don't remember seeing anything. Regardless I haven't seen any other popups since the few just after it finished calibrating.
