VMS dead - help needed !!!
Discussion in 'Roadster' started by warden_clyffe, Jul 26, 2018.
  1. warden_clyffe
    warden_clyffe Member
    Germany
    i do have a 2011 2.5 roadster here with a defective VMS.
    fortunately i had a working VMS from a 2009 2.0 junker with the same SW, so the roadster is running again BUT with the wrong VN in the VMS
    this actually doesn't sound too bad as the car is running perfect with the other VMS but is getting some errors permanently like "suspicious milage on odo" etc.
    before you recommend me to consult my friendly SeC: they CANNOT help (!)
    does anybody know a solution for this ?
    please pm, THANKS !
  2. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    If you put more than a few miles on the car, you’ll likely have a permanent mileage tamper warning. The VMS needs to be reprogrammed with the correct VIN and mileage. Only the SC can do that, and only someone with very specialized knowledge would know how to extract the current mileage from a different module in the car to code it to the replacement module. Service centers are likely only equipped to code new parts, not to reprogram used parts.
  3. warden_clyffe
    Germany
    thanks, means to me that i have to contact all available SeC's untill i find
    a) one with a VMS in stock,
    b) somebody there who knows where the "Roadster-Laptop" is and knows what she/he's doing
    sounds like the needle/hayshack-issue :(
