VMS Fflash replacement
spaceballs
636
115
Sammamish
Just FYI, if you have flash going out, you can pull the flash ic, dump it, then reflash to new one and then solder back in.
From what I can tell the flash isn't written very often, mostly it's just logs, and it's filesystem i think uses wear-leveling.
gregd
2,587
1,802
CM98
Cool!
With an embedded system like this, what are the externally-visible signs that the flash is "wearing out"? Anything in the logs that we should be looking for?
