VMS/PEM key mismatch ID 888
Discussion in 'Roadster: Technical' started by Hebbe213, Nov 18, 2020.
  1. Hebbe213
    Hebbe213 Member
    41564 KAARST, Germany
    Have since a couple days this error message on the screen when starting. Anything I can / must do?
    Any tip is welcome / Thanks / Hebbe
  2. Roadster
    Roadster JdeMO Powered
    SoCal
    Per the VMS Wiki, it seems like you may be trying to start the car without disarming it first.
    IDColorText under normal circumstancesDebug text (not normally displayed)Notes / Suggestions
    888
    Red
    Disarm vehicle with key fob before starting
    Press the button on the keyfob.
  3. X.l.r.8
    X.l.r.8 Supporting Member
    Toronto/Miami
    Canada and Europe share the same immobilizer, if you unlock and start within 30 seconds it will be fine, if however you get gripped by passers by asking questions and delay putting the key in abs turning the ignition then you will get that error, I Automatically press the middle button as I’m turning the key now.
    • Helpful x 2
