Voice Command Button
Crazy but yes honking the horn does activate voice command and also when I open the front doors too.
How did you ever realize that?
Unfortunately each time you want to activate you need to hit the horn !
Need a firmware update asap
Reactions: Prairie
I read it on another forum. Mine doesn’t activate opening the doors.
Sure seems like it needs to be a software update, what’s even more strange when I called Tesla they are saying it’s the hardware for the button and are sending out a mobile service tech.
I wish, tried a couple times no luck…also same thing the first two times , it’s a hardware issue
I just replaced my switches myself last month and all worked well until recently. I took the steering wheel off today and replaced the harness and still the same issue. I installed the old switch and still the same issue. I am wondering if there is a pinch somewhere that screwed up the brown connector harness and not seeing it.
Every time I get in the voice command comes on. The horn activates the voice command. The issue is the scroll wheel and top switch, the bottom switch works fine.
I will contact the service center for software update that may fix it.
Only thing that will fix it is a new airbag module!!! Whole airbag assembly comes with new switches also. It’s basically the entire center of the steering wheel
