Voice command not working 2020.44.10.
danarcha
77
115
South Bend, IN
When I updated to this version the voice command function stopped working. Has anyone else had this problem or have a solution for it.
I think I'm having the same issue. I upgraded to 202.44.10 a couple days ago. Today, when I press the right scroll wheel, the green circle with the microphone comes up, but when I speak, nothing happens. None of my words are transcribed and after a few moments the green circle with the microphone disappears. I tried a reset by holding down both scroll wheels but this didn't solve the issue. I'm also interested if others are seeing this and if anyone has found a solution.
mwfriederichs
26
58
Indiana
Weird, I could receive texts, and have them read to me, but could not respond. The green microphone icon would come up, but no recognition of my speaking, as if the mic were turned off.
MY_Maine
New Member
Jun 29, 2020
3
0
Belfast, ME
2020.44.10.1, Model Y
voice commands not working. I turn down sound from music off to ensure no interference. I tried fan speed, wipers, "play" function for music, did not try phone. At one point it did respond to fan speed setting. I also noted unusual behavior with automatic bright lights. It did not initially respond until I manually turned it on. Then the system turned the lights down with approaching car and then backup.
Look forward to next software correction. I might skip upgrading so quickly after release in the future.
skygraff
189
154
Chicago
Initially working then had a fail when I tried to do a bug report. Had reset right after update and did so again after fail. So far, responsiveness seems on par with previous versions.
That said, they still haven’t fixed the issue with voice commands not playing TuneIn stations (opens the search window instead - so even worse for hands free/safety). After this update, in fact, it devolved to the point that the same behavior now happens when attempting to play (favorited) FM stations.
MJB-CO
57
54
Colorado Springs, CO
After this update as usual I did a full shutdown and button reset. Didn't have mic problem but I didn't have any audio, not even turn signals. Did another full shutdown - problem resolved.
