Yeah, I noticed that "tire pressure" is no more. Sucks because I used that command almost every day!Is anyone experiencing a problem with voice commands after the V11 update? I tried the same commands I always use, Display Tire Pressure, Display Odometer, Turn On Wipers and Navigate to ……. and none are recognized.
Some of these commands no longer work. Worse some of them do the unexpected.I've been using Tesla Voice (website for all updated voice commands confirmed and curated by owners)
One of Tesla greater failures is not documenting the voice command set. They can include juvenile humor but apparently can't be bothered to provide proper documentation. Unless of course they intend that you only use the commands listed on the voice commands web page that still work.Can someone please point me at a list of voice commands that have worked prior to v11 rollout?
Ron
The other day I changed my wheel configuration as I removed the aero caps. Tire pressure when you select service was gone, just the button choices. Figured car may need to reset the pressures. After 40 miles still no car and pressures only the buttons. Set the wheel configuration back to the aero wheel covers and like magic the car and pressures re-appeared on the services screen. Set back to the caps and the car and pressures disappeared.Yeah, I noticed that "tire pressure" is no more. Sucks because I used that command almost every day!
Open/Show Trips Settings does not work for me. Has it worked for anyone?I've been using Tesla Voice (website for all updated voice commands confirmed and curated by owners)
Tesla Voice Commands
Crowdsourced reference of Voice Commands discovered in latest versions of Tesla OSteslavoice.glideapp.io
Here are the voice commands that most will be using with the updated UI in v11:
- Tire Pressure: Open/Show Service Settings
- Display Trips Card/Odometer: Open/Show Trips Settings
- Turn on Seat Heaters: Set (Driver/Passenger) Seat Heater to (1,2,3 or Low, Medium, High)
- Save Dashcam: Save Dashcam
- Sentry Mode: Enable/Disable Sentry Mode
- Set Wipers: Set wipes to AUTO, 1/2/3/4, OFF
- Tesla Specs: Hello Tesla
- View Release Notes: Show/Display Release Notes
I'm guessing they have a few bugs to work out.
I tried it today and couldn't get it to work with:Open/Show Trips Settings does not work for me. Has it worked for anyone?
Received an update (2021.44.30.7) yesterday and the pressure display issue is no more. Guess the pushed out a few patches.
There's still a voice command for the steering wheel heat. E.g "enable steering wheel heat" or similar works for me.my heated steering wheel command stopped working also
I think most of the commands that used to accept a numeric setting have switched to increase/decrease/etc. with the given number or some fixed number. Fortunately temperature still works.What the heck is this?
Why?I think most of the commands that used to accept a numeric setting have switched to increase/decrease/etc. with the given number or some fixed number. Fortunately temperature still works.
