Voice dialing the phone
Discussion in 'Model S: User Interface' started by FlyingJat, Apr 30, 2015.
  1. FlyingJat
    FlyingJat Member
    Washington - the State
    Is there a way to SPEAK the phone number to be dialed if its not in your contact list? I get paged and have to type in the number on touch screen.
  2. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I've never tried that, but did you try using the voice command function (hold down the voice button on the steering wheel) and saying something like "call 123 446 7891" ?
    Easy to try...
  3. LetsGoFast
    LetsGoFast Active Member
    Virginia
    #3 LetsGoFast, Apr 30, 2015
    EDIT: Ignore this. I apparently can't keep my cars straight in my head:
    "call 123 456 7890" works pretty smoothly. Its best if you pause briefly between call and the numbers and try to talk like a robot.
  4. pgiralt
    pgiralt Supporting Member
    Cary, NC
    This must be new because this used to not work, but admittedly I haven't tried it since something like the 4.5 or 5.5 release.
  5. LetsGoFast
    Virginia
    Now I've lost confidence, but I'm pretty sure I've done this. I'm about to go to lunch and test it.
  6. scaesare
    scaesare Well-Known Member
    NoVA
    Hmmm...
    Voice number dialing might be enabled.
    Elon suggested there's a new easter egg in the latest firmware....
    <runs to car to dial 867-5309...>
  7. LetsGoFast
    Virginia
    It still doesn't work. I'm obviously confusing it with my other car.
  8. mikeash
    mikeash Active Member
    Fairfax, VA, USA
    Most smartphones can handle this task on their own these days. On an iPhone you can just hold down the home button until it beeps, then say "call 1234567890." If it's paired with the car, it'll use the car's speakers and microphone. Android phones should be similar, I just don't know how you activate it there. Just requires reaching into your pocket instead of using the button on the steering wheel, which is slightly more annoying, but not bad.
  9. pgiralt
    Cary, NC
    In iOS 8, you can turn on "Hey, Siri" and you don't even have to press the button. This is how I make most calls these days. Just requires that your phone be connected to power, so you'll have to have the phone out of your pocket and plugged into an adapter for it to work. Works much better than trying to use the Model S voice commands.
  10. mikeash
    Fairfax, VA, USA
    Somehow I managed to completely forget about that feature, even though I'm a professional iOS developer. If you're in the habit of keeping your phone plugged in while you're in the car, this does indeed work very nicely.
  11. FlyingJat
    FlyingJat Member
    Thanks all. I will try the iPhone plugged in.next time I am driving around at 2 am on call. Sure would be nice to skip the step and have Tesla expand its voice commands.
