Voice not working
Discussion in 'Model 3: User Interface' started by skierrob, Jan 5, 2020.
  1. skierrob
    skierrob Member
    Long Beach, CA
    #1 skierrob, Jan 5, 2020
    I downloaded 50.7 two days ago. Since then I notice that about 80 percent of the time voice commands are not working - if I press the button for a voice command it does not hear my voice and all and just prompts me to talk. Other times it will sit like its waiting for me to talk for 30 or 45 seconds and then show what I said when I first pressed the button.
    Any ideas? Anyone else seeing this? It’s almost like I have a bad microphone or something like that.
    FYI - I did a reboot of the system once and voice worked for a bit after that but then stopped working again.
  2. cbaaz
    cbaaz Member
    arizona
    i see pretty much the same thing on 50.1. If I tap the green mic icon to close the session and then try again, it will barely usually (60% ?) work the next time. The voice commands are pretty much not practica/usable for me at this point. I was hoping 50.5 would fix it, but that download has been stuck for about a week :( - hoping it can be resumed by service soon.
  3. huangm777
    huangm777 Member
    Southern California
    After working decently for a few days it seems the voice commands aren't working for me either--maybe 1/4 times does it pick up on anything. Sigh. Guess I'll have to go back to not relying on it like I used to...I was starting to warm up to it.
  4. plusonechoi
    plusonechoi Member
    S. San Francisco, CA
    Worked great the first few times, now seems to only work about 50% of the time.
  5. JulienW
    JulienW Active Member
    Atlanta
    Seems that when each bug update we are getting MORE bugs on the Voice Recognition. Steering wheel button almost never works for me and touching the on screen button seems to be 50-50 or at best.
  6. cbaaz
    cbaaz Member
    arizona
    My download was “unstuck” by Tesla remote service and I am now on 50.7. I used voice commands 2 times today. First time, it worked on the first attempt. Second time, it failed four times and worked on the fifth attempt.
    At this point, I think it’s more of a safety reduction due to the distraction factor. :mad:
  7. Dan123
    Dan123 Member
    Miami
    Same experience here. I found it too unreliable to use. Works less than 50% of the time, and most of the time gets stuck in the listening mode, and then suggests "Navigate to Palo Alto" command.
  8. PianoAl
    PianoAl Member
    Far Northern California
    It's the same for me. Has anyone experimented to see if there are any parameters that make it more likely to work? For example, speaking more loudly, waiting a second before talking, etc?
  9. Andy_STL
    Andy_STL Member
    Saint Louis
    Same here. Voice commands are hot garbage. Not only that, my wife's name is Dorie and when I say "call Dorie" it reads Dory and says that contact does not exist. I never had that issue on previous versions. Major step backwards this update. Answering texts is useless as well.
  10. 640k
    640k Member
    Cincinnati
    everything i see posted has been anecdotal. i think we need to first understand if voice control is server-side (has to fetch translation) or client-side (loaded locally). if server-side, it's probably dropping a ping/handshake and the transaction never completes. if client-side, there's likely an out-of-order things of processing happening and it gets tripped up on the command.
    when i first got the feature, it worked fine for a couple days, then completely bombed. after the latest update it will work to initiate an SMS but will never take anything to dictate said message.
    i haven't figured out how "submit a bug report" works, but i've been doing it almost every time.
  11. SoccerMan94043
    San Jose
    Dito since (at least) 50.5. But as long as I hold down the right wheel and speak slowly, until I see it registered on the screen, it works. I used to be able to press once then say whatever and it handled it.
    I'm wondering if this might be some hardware 3 thing (longer time to process on older hardware).
  12. traxila
    traxila Supporting Member
    NYC
    Yes. Voice commands dead.
  13. Kevy Baby
    Kevy Baby Dis-Member
    Brea, CA
    Try gargling with salt water
    • Funny x 2
  14. calidreamz808
    calidreamz808 Member
    Huntington Beach, CA
    it's hit or miss for me as well. Quite annoying but i'm sure they will fix the bugs.
  15. Darmie
    Darmie Supporting Member
    Clear Lake TX.
    Can't find where I read this however, I remember reading that after these updates on the new voice commands to do a reboot with any or all USB ports disconnected. Something about that module could not reboot for the USB's still in place.
    • Helpful x 2
  16. cbaaz
    cbaaz Member
    arizona
    Thank you for posting this......
    I tried it today. Pulled *ALL* USB cables and rebooted. So far, voice is WORKING 100% (roughly 10/10).
    Granted, I'm only 1 datapoint with about 10 samples, but it's sure as hell worth a try.
  17. Colecaz
    Colecaz Member
    Phoenix, AZ
    Pulling the dashcam/sentry USB and rebooting fixed my 2020 LR AWD voice recognition too. Running .50.7 firmware. Thanks for the suggestion.
  18. rickghome
    rickghome New Member
    San Diego CA
    This is a user experience disaster. Voice input is so essential to the Tesla experience. It's really shocking they'd ship such poor software.
  19. plusonechoi
    plusonechoi Member
    My update from previous post. Voice seems to be working much better now, closer to about a 85% of the time!
    Not sure how related if at all, but I did have to reboot the car recently because I was not getting FM radio signal (which is also working great now post reboot)
  20. Toumal
    Toumal Member
    Austria
    I am using german language. Voice input now works very consistently, but using anything other than complete known phrases does not. For example:
    Navigate home - works
    Navigate to work - works
    Navigate to example road 5 - unknown command.
    Open glovebox - works
    Interestingly the error message is in english even though system language and my spoken words are german. Text is recognized correctly, just not acted upon.
    Tried rebooting, tried changing language to english and then back again. No joy.
    Workaround: press navigate, THEN use voice input to "type" in the address box, then press return.
