Void cheque problem for delivery day
Discussion in 'Canada' started by Darthbenji, Jun 1, 2018.
  1. Darthbenji
    Darthbenji Active Member
    Ontario
    I know I’m supposed to give them a void cheque for payment withdrawal but I don’t have any. I haven’t written a cheque in years. TD has a preauthorized withdrawal form that you can print and it contains all the info that would be on a cheque that I can give them. Anyone use this?
  2. sitter_k
    sitter_k Active Member
    Toronto (GTA)
    Should be sufficient, all the want is the name of the account holder branch, institution and account number.
  3. trevorc
    trevorc Member
    Niagara
    I used a similar CIBC form in the end since they didn’t like that my void cheque didn’t have my current home address printed on it.
  4. Tony_YYZ
    Tony_YYZ Tezler Guru
    Caledon, ON Canada
    Hrmm, thanks for the heads up. My current cheques do not have my current address. My plan was to just draw a line over it but if that's going to be a problem then I'll have to get that form from CIBC.
  5. trevorc
    trevorc Member
    Niagara
    Yeah, I had drawn lines over the old address and written the right one beside it in advance but that still didn’t cut it.
  6. Tony_YYZ
    Caledon, ON Canada
    Glad to see this now. I'll obtain one of those forms tomorrow from the bank when I go to get my draft.
  7. trevorc
    trevorc Member
    Niagara
    It’s also available online at
    https://www.cibc dot com/ca/pdf/payroll-direct-deposit-PAD-form-en.pdf
  8. Tony_YYZ
    Caledon, ON Canada
    Yeah i just found it, filled it and printed it. Thank you!
  9. trevorc
    trevorc Member
    Niagara
    Sure thing! That was one of the thorns in my delivery that I’m glad you won’t have to experience!
  10. Darthbenji
    Ontario
    Does it have to have your address on it? The Td printable preauthorized debit form doesn’t have an address at all.
  11. trevorc
    trevorc Member
    Niagara
    They should be okay with the standard TD pre-authorized form, but they didn’t like the wrong address being printed on the void cheque from what I understood. Also the guy kept saying I should have an option in my online banking to print a “void cheque”, which doesn’t exist for CIBC. If you have that option with TD you could use that too. I’m assuming your TD preauth form would go through okay. I didn’t understand why there was a difference in my writing my address on the CIBC form vs. on the void cheque aside from the fact that the form had a signature line.
  12. Darthbenji
    Ontario
    Does the Cibc form have your address on it or did you write it there?
  13. Tony_YYZ
    Caledon, ON Canada
    It has a field for you to type in your address.
  14. Darthbenji
    Ontario
    Td’s doesn’t. Just has name and all the banking numbers.
  15. trevorc
    trevorc Member
    Niagara
    Does it have signature and date fields though?
  16. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I set up a bank transfer on my Tesla. It worked just fine to transfer the money after I inspected the car.
  17. trevorc
    trevorc Member
    Niagara
    My void cheque was more for RBC financing. I had a bank draft for what was due on delivery.
  18. Darthbenji
    Ontario
    07CCBE4A-AC2A-4D1F-B408-5D87D04DD24B.jpeg Nope. I’ve attached what it looks like. I’ve blacked out my name and account number. That’s it.
  19. trevorc
    trevorc Member
    Niagara
    I’m not sure what to tell you.
    Do you have an option to generate a faux void cheque in your online banking? The Tesla people at the IC seemed to think some people could do that.
  20. trevorc
    trevorc Member
    Niagara
    Hopefully they accept the form you have since this is the verbiage on their web site, emphasis mine. The Tesla people seemed to like it when the CIBC form said something similar.
    If you don't have a cheque
    If you do NOT have a cheque, you can locate the account information you need in EasyWeb. Simply login, select the account you want to view, and then select the "Direct deposit form (PDF)" link in the upper right-hand corner. The form provides your account information in place of a voided cheque and is used when arranging for direct deposits or pre-authorized payments.
