This makes it a bit more of a direct competition in California. I'm sure many hybrids were sold for the HOV access alone.
Nice...all the public charging stations that we take for granted now will be clogged with prius drivers, plugged in for hours, topping off their "8 mile" batteries.
Prius will be plugged in for 1.5 hours. A Roadster would be there 8.
That is just a result of the acceleration need of the cycle. If that acceleration was called on in the beginning, AER would be a few feet.All electric range = 6 miles.
A lot of the public stations (that I have seen) usually have people who are plugged in regardless if they need a charge or not. For example Prius owner plugs into the EV charging station at their workplace and are plugged in for 8 hours, where as a someone who really need the charge (i.e. pure ev vehicle) cannot charge for the duration that plug in hybrid is plugged into the station (regardless if they are charging or not). There will also be far more Plug in hybrids sold than Pure EV's, so this will take a huge chunk of current public charging stations that we use out of commission, since they will be monopolized by the plug in hybirds.
WTF- 6 miles!! c'mon
Anyone who buys one of these for over 32 K is a fool.
Let's see, spend 23 K on a normal Prius and get a Hymotion (A123 system) or a "clone" for 10 K installed and have about 20-40 mile AER
6 miles AER = 32 K
20- 40 miles AER= 33 K
The 29 kWh / 100 miles estimate is based on wall socket consumption, not usable capacity. The PiP takes about 3.0-3.2 kWh to charge so that gives 10-11 miles. The EPA range estimate is 11 miles but that includes 0.022 gallons of gasoline because the gas engine started up during the test cycle to assist for power and/or vehicle speed reasons. The EPA estimates are a bit conservative so it will be easy to get 13-15 miles with careful driving.Some people argue the PiP has zero AER for the same reason. I think the 8-9 mile number is a bit closer (given the battery has about 2.5kWh usable, 29kWh/100 miles gives 8.62 miles).
