Vossen CVT 22x9 and 22x10.5 255/30/22 & 295/25/22 ? RUB?
Discussion in 'Model S: Interior & Exterior' started by Fonz19, Apr 19, 2014.
  1. Fonz19
    Fonz19 Member
    Albuquerque
    Hey guys Im new new here so if this has been posted before I apologize.
    I hope i Made the right Choice here on tires I just got my vossen CVT directional wheels 22x9 et30 front and 22x10.5 et38 Rear in last week which i am sending out for charcoal Grey powder coat the tires size i bought 255/30 and 295/25 which was recommended by vossen but now im hearing that 245/30 and 285/25 is what i should of went with. has anyone had any RUBBING problems in the front with the 255 on a 22x9 ? My MS will be here april 29th already have appointment for full Xpel clear wrap, tint and black vinyl wrap all the chrome and install wheels, ill post pics.. but for now im stressing out on these damn tires.. :cursing:
    Thanks guys
  2. rekoh
    rekoh Member
    Minnesota
    I am not 100% sure, but I know someone on here will post with absolution. I would say you are fine.
  3. Fonz19
    Fonz19 Member
    Albuquerque
    Thanks rekoh,
    vossen said that 22x10.5 will fit i dont think i believe that
  4. FlyYellow
    FlyYellow Member
    SF Bay Area
    i have 22's as well and i have a 22x9 in the front. I have a 255/30/22 on the front and it rubs ever so slightly only in reverse. I would NOT go to a 245/30/22 because you have a weight rating problem. Technically even the 255/30/22 is under spec for max load. My recommendation is to go 255/30/22 in front and 265/30/22 in rear. You could move up to a 285/30/22, but our cars are tuned to handle a certain way and if you create too much of a staggered tire size, the car will likely push under hard cornering. So my recommendation is to stick to a 265 and not go to a bigger size...
  5. LuckyLuke
    LuckyLuke Model S P90DL
    Eindhoven, The Netherlands
    285 rear is actually pretty nice, very very good traction, bit light understeered when driving on the edge though, 265 would be more balanced and a bit more efficient (I think my setup uses 10-20% more than the factory 21/19" sets), and I don't think you can put 265 on a 10.5 rim, that rim needs 285 or 295.
    I have a 20" set Vossen CV4 front 20x9.0 ET35 with 245/40/20, rear 20x10.5 ET42(+5 spacer) with 285/35/20.
    Also realize that with 22" you loose quite some comfort. I know at least one owner that traded in his 22's within 24hrs of use because the ride was too rough.
  6. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    I think they've reversed their position on that statement. I asked them a few months ago about this exactly and if I recall they said while they initially fit, after they posted those figments they discovered problems later (rubbing) and now don't recommend going that wide in the front.
  7. roadking40
    roadking40 Member
    Chandler AZ
    I am running the following with no issues - 22x9 front w/245/30/22, 22x10.5 rear w/295/25/22
  8. Fonz19
    Fonz19 Member
    Albuquerque
    thats the tire size i was told to go with Roadking, do you have any rubbing at all? what offset are your wheels? my car will be here next week and i need to know if should get new tires sizes or not...GRRRR
    this is a very controversial issue seen every where thats what makes it so hard
    - - - Updated - - -
    Maybe ill just get all new tires 245/30/22 and 285/25/22 ????????????????????? call it day. these 255/30 and 295/25 seem like there gonna be a problem .. anyones last words ??????????
  9. Fonz19
    Fonz19 Member
    Albuquerque
    I think Ill follow what your doing roadking40 ill just replace the front tires to 245/30/22 and keep 2905/25/22 rear..... do you have any rubbing in rear tires?
  10. FlyYellow
    FlyYellow Member
    SF Bay Area
    Honestly i wouldn't do 245's. The factory setup has a load rating of 1565 lbs per wheel. The 245/30/22 is 1389 lbs per wheel. That's a difference of 352 lbs in the front of the car and that is a lot! There's plenty of room up front for a 255 especially if you push the offset out by 5mm. BTW the 255/30/22 is 1522 lbs but that's pretty close to the factory.
    I personally do not mess with tires. A blow out in the front can be a life threatening event at freeway speeds and that's why most reputable tire shops won't even install a under "load range" spec tire. So you may wish to shop around for a shop that's even willing to do it (that should tell you something in itself).
    FWIW.
  11. Fonz19
    Fonz19 Member
    Albuquerque
    i guess 255/30/22 front and 295/25/22 rear wheels should be done powder coating friday i guess ill let you know
  12. Ghia64
    Ghia64 Member
    Tellgren
    Looking forward to see photos of this! :love:
  13. Fonz19
    Fonz19 Member
    Albuquerque
    Ill Post Pictures when my wheels get put on, But I still cant sleep over this tire issue lmao contemplating on front tires i already bought 255/30 but keep thinking about 245/30 GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
  14. logan
    logan Member
    San Diego, CA
    255/30/22 should fit fine; I have them on my CV4s. There was some minor rubbing when turning in reverse at low speeds but we put some spacers on them and it helped.
  15. Fonz19
    Fonz19 Member
    Albuquerque
    changed from 255/30/22 to 245/30/22 now i keep hearing bad storys with 22x10.5 ET38 with 295/25 GRRRRRRR anyone having problems with 295/25 ?
  16. ibxspeedracer
    ibxspeedracer Member
    South OC, CA
    Hey Fonz. I heard from my guy in SD that you'd ordered your CV4s from him! What a small world. Looks like Logan is running the same as you down in SD with 255/295 front/back. I'm staying with 245s on 8.5"/9" on the front and have the 295-25 already on hand for rears so once Niche confirms whether they recommend 10" or 10.5" on the rears I'll get the 295/25's on and be able to once and for all tell... Since we talked I found out it will take 4-6 weeks for these forged Niche Targa customs wheels to get produced. The best about them is I'll be able to a variety of choices in tires at more reasonable price(s) and best of all, the rims wills range from 24/27lb. each which means ill safe a ton of rotational weight vs my stock 21" and maybe this would increase my range a bit! Will keep in abreast pal. S
  17. Sexyp85
    Sexyp85 Member
    Davie
    Interesting thread... feel free to inbox me for specs 20190928_123956.jpg 20190811_205805.jpg
  18. colindo1990
    colindo1990 Member
    San Diego
    255 will rub on full lock turns
    22x10.5 et 38 will rub on the inner liner, I had et 35 on my last set and it barely cleared
  19. colindo1990
    colindo1990 Member
    San Diego
    get 245/30/22 with 97 load rating and u should be fine
