Thanks for the article. A couple of points:
"The Chevrolet Bolt can charge at up to 55 kW which is 20 percent faster than at older 50 kW chargers installed in North America today"
Should that be 10%? Or is the issue with the current the 50kW chargers are capable of delivering for a given voltage?
"The only car known to utilize 350 kW charging is the Porsche Taycan (previously known as the Mission E) and it is not expected until late 2019."
You might want to consider saying "claimed to"... as I don't think it's been proven yet. What's more, the EA stations are 150KW @ 1000V, and as the Taycan is an 800V architecture (with peak power delivery somewhere around 700V before taper), it's not likely that it will see more than 250kW unless the ABB chargers EA is installing are using liquid cooled cables and handles we are unaware of to get past the 350A rating....
The 20% is correct. The charger is rated for max amperage at max voltage, but the cars are never drawing the max amperage but the time they hit the max voltage (and many cars can't reach the charger's max voltage.)
The Bolt tops out in the mid forties on the best previously available chargers, the 125A limit ones.
