Waiting to find the perfect P85+ or no +?
Discussion in 'Model S' started by irvineboy, Feb 11, 2015.
Tags:
  1. irvineboy
    irvineboy Member
    Irvine, CA
    I am fine with a used 2013 or 2014 P85.
    The only thing I want are the electric powerfolding mirrors. I was told the car had to be made after Nov 2013 to have them. That rules out almost all the 2013 P85 out there. So it looks like I have to get a 2014 P85.
    A lot of the 2013 P85 have the performance plus package. Is this noticeable? I am planning to get ones with 21" grey cyclone tires anyways. Will the performance plus add anything like better handling and steering (for someone that doesn't track the car)? I just want a gray on black, preferably with black headliner. But all the ones I have seen are tan or grey headliner.
  2. dennis
    dennis P85D
    Silicon Valley CA
    If you want BMW-like handling, get a +. If you are satisfied with Lexus/Mercedes style handling, don't bother.
  3. SherSlick
    SherSlick Member
    Denver, CO
    I think the only difference on the + was the staggered fit tires (wider in the back). If you find a P85 and a set of the staggered fit tires/wheels you will have a P85+.
    Or vise versa.
  4. andrewket
    andrewket Well-Known Member
    No, the suspension is different. Over time some of the components made their way to all model S vehicles, but in 2013 there was a significant difference between a P85 and a P85+.
  5. spentan
    spentan Active Member
    SoCal
    If I was buying a used Model S, make sure you buy one with Autopilot.
    It is definitely worth it!
  6. irvineboy
    irvineboy Member
    Irvine, CA
    I thought only the p85d had autopilot?
    - - - Updated - - -
    Harsher stiffer suspension?
  7. spentan
    SoCal
    Nah, there are a few S60s, S85s, P85s and P85+s that came with Autopilot (mid-late 2014).
    I'd be on the hunt for them, if someone is looking to upgrade to a S85D/P85D.
    You could post a wanted ad in the forums even a "Make me Upgrade" of sorts.
    Also, check with Tesla for an inventory vehicle
  8. dennis
    dennis P85D
    Silicon Valley CA
    What made it into all models during 2013 were stiffer bushings for the rear subframe and the rear lower control arms. The remaining unique suspension elements for the P85+ are:
    1) Larger sway bars front and rear
    2) Stiffer bushings in the rest of the rear suspension elements
    3) Different valving for the air dampers
    4) Wider rear wheels and tires
    These make a BIG difference in the overall handling of the car IMO.
  9. zwede
    zwede 2013 P85+
    Plano, TX
    The biggest difference for me with the plus is the steering. Non-plus has much less road feel.
  10. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I am very happy with the handling of the +. Quite nimble for such a heavy car. The replacement cost for tires is a killer though. Mine was delivered 9-29-14 and has all the autopilot features. I believe, based on Elon's comments, those features were added to the production line approx 9-15-14. I just made the cut and I love it. Whew!
  11. irvineboy
    irvineboy Member
    Irvine, CA
    So how does the P85 performance plus handling and steering feel compared to the P85D? I am not talking speed because you can't compare the two. I mean the handling and steering.
  12. zwede
    zwede 2013 P85+
    Plano, TX
    Haven't driven a P85D yet, so don't know. I can tell you I was rather shocked at the difference between my P85+ and a loaner S85 on coils w/ 19's. I was prepared that there would be a difference, but not that it would be so drastic and that it would be so noticeable when just driving around (not hot rodding it).
  13. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    That said, I found the stiffer bushings in the LCAs the primary benefit of the +. As of at least 11/2013, all Model S were shipped with those. The larger sway bars added a hint of twitchyness that I didn't really enjoy, which I believe lola referred to as "head snatch" as you go over uneven pavement. The wider rear tires help, I'm positive of that, but I'm less positive they're well-suited for a daily driver. The inability to rotate tires locks you in to higher maintenance costs unless you swap to non-plus wheels.
    #3 above might make a big difference. I was extremely unimpressed with the handling feel of all the air suspension varieties in around the timeframe he's looking, though, which is why I ended up with coils (and why lola switched his P85+ to coils).
    Every time this comes up, all I can suggest is to drive a couple. It's awfully subjective. If you're getting air either way, the plus definitely handles better. You'll have to decide if the extra up-front and ongoing (tire) costs make it worthwhile.
    Some further notes for OP: You're correct. 11/2013 is when the folding mirrors started rolling out. Mine delivered 11/23 and was the only vehicle that went out that day that had them (it was just about to enter production when I had them switch to the new tech package at the last minute). So for 2013s you have a month an a half worth, at most, and nearly all of those are going to reside in CA since they delivery primarily to CA in December to pad their numbers.
    Second, the black headliner wasn't an option in 2013. I don't recall when it was added, but it was at least a few months into 2014.
    Good luck in your search. Let us know if we can help!
  14. Rbats
    Rbats Member
    Chicagoland
    You can buy mine! :biggrin: Items for sale under my forum name.
