Waking up IC on bench without MCU
So I now have the MCU but obviously the ICs firmware doesn't match and thus it refuses to work. Is there a way I can redeploy the software onto the IC, without rooting the MCU?
Also it still has data in it from the previous owner, can I factory reset the MCU to erase all data without any issues?
You should be able to factory reset without problems connect cluster while doing that may factory reset cluster
I think you can do a redeploy of a specific unit, for example just the IC with a special command commenting out the rest of the modules in the "car". I will look into it for you.
What MCU & IC version do you have? Also, yes, you can do a factory reset to erase all data from the previous owner. No problems.
Reactions: FoxIrate
Currently running v8.1. I will have to look when I get home which exact build but something with 2018 I believe
Reactions: iTech75D
you can redeploy firmware by going into service mode. hold down the "model S" in the "service" menu page and then when the dialog box pops up type "service". should go into service mode and one of the options will be "redeploy firmware".
Reactions: iTech75D
FoxIrate , thank you.​
with you, it`s easy, if I can help, write me.
Code:
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:4130            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:21576           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:28493           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:sunrpc          0.0.0.0:*               LISTEN
tcp        0      1 ic:43148                cid:4035                SYN_SENT
tcp        0      1 ic:43150                cid:4035                SYN_SENT
udp        0      0 224.0.0.26:4401         0.0.0.0:*
udp        0      0 127.255.255.255:4455    0.0.0.0:*
udp        0      0 0.0.0.0:4998            0.0.0.0:*
udp        0      0 224.0.0.26:4501         0.0.0.0:*
udp        0      0 0.0.0.0:58773           0.0.0.0:*
udp        0      0 224.0.0.26:4509         0.0.0.0:*
udp        0      0 224.0.0.26:5031         0.0.0.0:*
udp        0      0 224.0.0.26:4033         0.0.0.0:*
udp        0      0 224.0.0.26:4051         0.0.0.0:*
udp        0      0 224.0.0.26:4061         0.0.0.0:*
udp        0      0 224.0.0.26:4071         0.0.0.0:*
udp        0      0 224.0.0.26:7655         0.0.0.0:*
udp        0      0 224.0.0.26:4072         0.0.0.0:*
udp        0      0 224.0.0.26:4091         0.0.0.0:*
udp        0      0 224.0.0.26:4093         0.0.0.0:*
udp        0      0 224.0.0.26:4095         0.0.0.0:*
udp        0      0 224.0.0.26:4097         0.0.0.0:*
udp        0      0 224.0.0.26:4101         0.0.0.0:*
udp        0      0 224.0.0.26:4105         0.0.0.0:*
udp        0      0 224.0.0.26:4111         0.0.0.0:*
udp        0      0 0.0.0.0:4130            0.0.0.0:*
udp        0      0 224.0.0.26:5161         0.0.0.0:*
udp        0      0 224.0.0.26:5165         0.0.0.0:*
udp        0      0 224.0.0.26:4148         0.0.0.0:*
udp        0      0 0.0.0.0:58426           0.0.0.0:*
udp        0      0 224.0.0.26:4163         0.0.0.0:*
udp        0      0 224.0.0.26:4171         0.0.0.0:*
udp        0      0 224.0.0.26:4181         0.0.0.0:*
udp        0      0 224.0.0.26:4201         0.0.0.0:*
udp        0      0 0.0.0.0:sunrpc          0.0.0.0:*
udp        0      0 ic:ntp                  0.0.0.0:*
udp        0      0 localhost:ntp           0.0.0.0:*
udp        0      0 0.0.0.0:ntp             0.0.0.0:*
udp        0      0 0.0.0.0:20101           0.0.0.0:*
udp        0      0 192.168.90.255:20101    0.0.0.0:*
udp        0      0 224.0.0.26:4231         0.0.0.0:*
udp        0      0 224.0.0.26:4241         0.0.0.0:*
udp        0      0 192.168.90.255:31415    0.0.0.0:*
udp        0      0 224.0.0.26:4281         0.0.0.0:*
udp        0      0 224.0.0.26:4301         0.0.0.0:*
udp        0      0 224.0.0.26:4305         0.0.0.0:*
udp        0      0 0.0.0.0:60133           0.0.0.0:*
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags       Type       State         I-Node   Path
unix  7      [ ]         DGRAM                    7428     /dev/log
unix  2      [ ACC ]     STREAM     LISTENING     5764     @/tmp/.X11-unix/X0
unix  2      [ ACC ]     STREAM     LISTENING     5154     /dev/nvrm_daemon
unix  2      [ ACC ]     STREAM     LISTENING     4909     /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     8257     /var/run/rpcbind.sock
unix  2      [ ACC ]     STREAM     LISTENING     4539     @/com/ubuntu/upstart
unix  2      [ ACC ]     STREAM     LISTENING     5741     /tmp/escalator
unix  2      [ ACC ]     SEQPACKET  LISTENING     5755     /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     4994     /var/run/fcron.fifo
unix  2      [ ACC ]     STREAM     LISTENING     5765     /tmp/.X11-unix/X0
unix  2      [ ACC ]     STREAM     LISTENING     5826     /run/upstart-udev-bridge/alive
unix  3      [ ]         STREAM     CONNECTED     5972
unix  3      [ ]         STREAM     CONNECTED     5821
unix  3      [ ]         STREAM     CONNECTED     5976
unix  3      [ ]         STREAM     CONNECTED     5892
unix  3      [ ]         STREAM     CONNECTED     7541
unix  2      [ ]         DGRAM                    5161
unix  2      [ ]         DGRAM                    7613
unix  3      [ ]         STREAM     CONNECTED     5158
unix  3      [ ]         STREAM     CONNECTED     7588
unix  3      [ ]         STREAM     CONNECTED     5165     /dev/nvrm_daemon
unix  3      [ ]         STREAM     CONNECTED     5977
unix  2      [ ]         STREAM     CONNECTED     8966
unix  2      [ ]         DGRAM                    7518
unix  3      [ ]         STREAM     CONNECTED     4914
unix  3      [ ]         STREAM     CONNECTED     8298
unix  3      [ ]         STREAM     CONNECTED     7589
unix  3      [ ]         STREAM     CONNECTED     5159
unix  2      [ ]         DGRAM                    6323
unix  3      [ ]         DGRAM                    5937
unix  3      [ ]         STREAM     CONNECTED     5973
unix  3      [ ]         STREAM     CONNECTED     5975     /dev/nvrm_daemon
unix  3      [ ]         STREAM     CONNECTED     4953     /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     5156
unix  3      [ ]         STREAM     CONNECTED     7585
unix  3      [ ]         DGRAM                    5938
unix  3      [ ]         STREAM     CONNECTED     4930     @/com/ubuntu/upstart
unix  3      [ ]         STREAM     CONNECTED     5891
unix  3      [ ]         STREAM     CONNECTED     5974
unix  2      [ ]         DGRAM                    7434
unix  3      [ ]         STREAM     CONNECTED     5914
unix  3      [ ]         STREAM     CONNECTED     4915
unix  3      [ ]         STREAM     CONNECTED     8282     @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     7586
unix  3      [ ]         STREAM     CONNECTED     5157
