Walk away door locks (home) - Alarm triggers every time!
GlmnAlyAirCar
1,385
1,125
Sanatoga PA
I am running into a strange problem. Every since receiving the update that allows "home" to be an exception to walk-away door locks (don't lock at home), the alarm sounds if I open the doors or trunk without the key in the immediate vicinity. The doors are in fact unlocked as I can simply open the doors, but the alarm seems to think the doors are still locked.
I tend to think this problem is unique to me since I suspect others would have reported it by now if they have the same problem.
One possibly (but not necessarily) related data point: I am running into problems with the key inside the car. Normally, I have my key in my pocket, and all works fine. However, if I place the key in the center console cubby by the USB ports, I frequently get the message "key not detected in vehicle." I move the key away from that area and the message goes away. I know there is a sensor in that area. If this sensor is defective, could it have some sort of effect on the alarm???
DerbyDave
514
276
Kentucky
That is strange. If the other key works fine, I'd try replacing the battery in the one that is not working correctly. Then try toggling the walk away lock feature, and see if any changes (and toggle home exception as well). Does the cubby, USB area of console see the other key?
GlmnAlyAirCar
1,385
1,125
Sanatoga PA
Yes already replaced the batteries. I haven't tried the other fob yet but I'll give that a shot. I have turned off the home exception and things go back to the way they used to work (no surprise). I'll try toggling the walk away lock settings and try that.
GlmnAlyAirCar
1,385
1,125
Sanatoga PA
I believe I figured out what is going on.
First, the key not found error. This started happening when I installed the wireless phone charger. With my phone charging, and my key sitting right next to the phone, interference is obviously the culprit. The problem doesn't occur if I don't have my phone charging.
After trying out many different scenarios, I discovered that the alarm only goes off when I summon the car while at home. Apparently, when summon summon finishes, it unlocks the doors (per the checkbox) but for some reason leaves the alarm activated.
boskog
14
6
Cary,NC
I just had my alarm go off after I summoned my car out of the garage, I recently enabled the home location exception for walk-away lock.
I'll have to experiment some to see if this always happens.
serendipitous
336
493
Maryland, USA
I had this issue yesterday for the first time, but I actually had the key with me. I reached into my pocket and had to double click the fob to stop the alarm from going off. I believe I had also summoned the car into the garage prior to this. Since I had the key, I'm guessing the bug is a little more subtle - it's like it doesn't even look for the key if the door opens when it thought the car was locked. I'll have to try something similar where it's locked but the window is down and I open it from the inside while I have the key.
JoeCW
28
20
DFW
I recently ran into this as well and can confirm that it was after I used the summon in and out of the garage. The weird thing for me is that I did not experience this until this week and I have not had an update recently or changed the lock when walkaway excluding home (always had that on). Granted, I've only had my car for 3 weeks and messing with all the features but I did test this out within the first week to learn how it works and did not run into this.
Anyways, wondering if there is a solution or exact triggering setting identified. Thanks!
GlmnAlyAirCar
1,385
1,125
Sanatoga PA
In the intervening weeks I have definitely determined that it is summon-related. As a workaround, I make it a point to, after summoning, lock the car with the fob. That way next time I am forced to unlock the car (which disables the alarm).
I haven't yet tried just manually unlocking the car immediately after summon. I'll report back if that works.
JoeCW
28
20
DFW
Will try also. Just can't pinpoint why I did not get this the week before but it might have ben me pushing the lock clock button first (by accident) instead of holding it down to engage summon as I was learning how it works.
JoeCW
28
20
DFW
Ok, all, from my testing, it truly does happen when you have lock when walking away set and exclude home. I did not run into this before as I was (accidentally or on purpose) pressing the key fob once before pressing down and holding it to activate summon.
As I like the lock when walking away feature and exclude from home, I will leave those and do the opposite order of @GlymnAlyAirCar by pressing the fob to lock the car then pressing/holding again to activate summon. This still gives me the natural coming up to the car and it presenting handles and unlocking.
Hopefully this is an identified bug and gets fixed in an upcoming update.
Hookemhorns
108
41
Georgia
I have the problem too. Double whammy tonight - summoned the car out of the garage. My wife then opens her door to get in, and the alarm goes off. I click my fob to stop it. Handles still out...I walk up to my door, open it to get in and alarm goes off again.
I have had walk away lock except at home both set and not set, and rebooted between these setting. Still happens. I think it is truly summon related. Since I summon in at night, it waits patiently for me to get in in the morning, and off goes the alarm, whether I summon it out of the garage first or just get in it in the garage.
I guess I'll try locking then unlocking when I get in first time after a summon. Hope that works. Tired of alarming/waking the neighbors.
Greg29
78
22
Orlando, FL
I ended up unchecking "exclude home" until this is fixed via update. I still cringe a bit every time I open the doors after summoning in anticipation of the alarm.
