Wall Charger Electrician Recommendation (SoCal, Riverside County)?
tempest2001
37
10
Riverside
Hi everyone,
Just got a gen 3 wall charger unit, I was wondering if anyone has any recommendation for electrician in the Southern California region specifically one willing to service Riverside County (Eastvale area)? I've gotten 3 quotes and they vary drastically. For a 15-18 foot run in the garage with 60amp breaker on a 200amp power panel with 2 open slots but may require moving some breaker, one quoted me $350 advised me no permit required and said don't ask about his license, another quoted me $2000 which included permit cost, and another quoted me $550 for first 10 feet and anything over that amount is $15 a feet + $250 permit service fee+city permit cost/inspection fee. Any recommendation will be appreciated.
Thank you,
Tempest
Merrill
Merrill
Jan 23, 2013
3,689
1,257
Sonoma, California
When I had my wall charger installed they had to run from the garage to my MSP which was around 75 feet thru the attic and they charged $1000 and that included a separate panel and meter just for the car charging.
tempest2001
37
10
Riverside
Yeah the SoCal electricians are pretty crazy. My power panel is just outside of the garage wall and there's already power cable that ran through the garage from that panel. They just need to run another into the garage run it inside the garage on the side and to the wall area near the car, I measured it worse case scenario 18 total feet maximum.
Need
2,875
2,193
SoCal
The 3rd quote sounds fair for this area (Inland Empire). Adding permit adds a lot to the installation as some cities require the electrician to be there during the city inspection. So he/she will have to be there the entire time when city gives a 4 hours windows when the inspector will come.
When I did our two NEMA 14-50 outlets at Rancho Cucamonga, I paid $300 for the first one (just at the other side of panel), and $550 for 2nd one about 1 garage door going up to the ceiling and come back down (20 to 25 feet?). I did not get the permits. I believe in our city, you can install NEMA 14-50 yourself without permit. The electrician I used is licensed, but he said it is up to me if I want to get permit or not. He said his work is all up to code. I don't remember how much he wanted to charge with the permit... I think it was definitely over $250 extra... probably closer to $500.
tempest2001
37
10
Riverside
Thanks for the information. I plan to call the city to see what the requirement is and if inspection is required. The $2000 company basically wanted $1000 for the install and $1000 for permit and believe it or not it's an electrical contractor directly in Riverside county but it's supposed to be Telsa certified which I thought it's pretty ridiculous, $1000 for the install I can see it if it was a difficult job but another $1000 for permit it's pretty steep considering what I see published in my city's website is a $240 permit fee for EV charging wall mount, I didn't see an inspection fee so I'll have to check. The $550 quote was from an electrician in LA county which is also Tesla certified.
t00shay
76
29
SoCal
I got an outlet install and the charger mounted inside my garage for 300. There was no permits required. I don’t have a Tesla charger as I have another ev to charge also. The total for the charger and install was $750. I just have to use my adapter for my model 3.
Big Dog
1,519
1,513
Irvine, CA
This is simple electrical work. We had a sub-panel installed in The OC as we only had a 100-amp box. But I used a licensed, bonded electrician and told him that I wanted an install that I could then have the city come out and permit. (It's only a $60 fee in our OC town.) The electrician said, no problem, if it doesn't pass teh permit I'll come out and make it right.
lUtriaNt
620
542
Los Angeles
used this cat to install a 14-50 at a house in redlands. all of these cats smell $$$ when you mention a Tesla. I just had him do a 14-50 right under a sub panel and he charged $350 or $375 - i forget. he was thorough and his work was spot on.
tempest2001
37
10
Riverside
Thank you, I'll check them out.
tempest2001
37
10
Riverside
Thanks.
