Hello All,
I'm currently prepping for new wall charger installation on Monday PM, drilling holes through concrete to accomodate wire conduits. I'm planning on running a PVC conduit directly from my basement up into the bottom of the wall charger, which will be installed using the high-profile bracket to space the unit a bit further from the wall.
Does anyone know what the distance of the bottom-entry hole is from the wall when the high-profile bracket is installed? I can't find this measurement anywhere online, and I don't want to mis-locate my hole drilled through concrete... the hole needs to be lined up precisely below the bottom-mount hole in the charger.
Thanks in advance for your help!
Don Field
Montreal, QC, CANADA
Don Field
