dogmodes
I feel like everyone has made it clear the temperature differences is the reason you can’t use 6/2-3 NMB vs using 6awg MC or in conduit. In all of the cases the actual wire is more then likely the exact same. However that added plastic sheathing acts as an insulator which lowers the overall rating. 3 cables in tight plastic sheath can overheat easier then 3 cables in a roomy conduit.Pricing per foot from www.wireandcableyourway.com
6/2 MC $3.38 75A
6/3 MC $4.50 75A
6/2 THHN building wire $1.06 75A
4/3 nm-b $11.73 70A
I'm tempted to go with the 6/2 and give up on any notion of installing a 14-50 down the road. They didn't have 6/3 THHN.
Didn’t catch what your run is but if you can’t find the right MC cable, or can’t just do PVC or metal conduit, you can buy empty MC cable at homedepot and feed a couple spools of THHN through it. Personally I’d go with 6/2 and if you want to swap it in the future, make it a 6-50 instead of 14-50 like you said.
