Wall Charger installed outside?
Discussion in 'Model 3: Battery & Charging' started by bomquito, Jul 17, 2018.
  1. bomquito
    bomquito Member
    So-Cal
    Anyone has experienced installing a Wall Charger outside of the garage?
    I was recommended a spot outside of my garage, on the stucco wall, as the electrician could not find a good spot inside my garage. He stated the wall chargers works outside as they are weather proof. Is this true? I am also afraid that the cord my get damaged once I close the garage door over (in case of at night charging). I think it's overall a bad idea.
    Your thoughts?
    Can't wait to pick up my model 3 on Saturday....
  2. Rocky_H
    Rocky_H Active Member
    Boise, ID
    Of course--otherwise every one of thousands of hotels with them outside has a problem.
    Oh, having the wall connector outside, but the car is inside? OK, yeah, that's not a very good idea. I thought you were talking about charging your car out on the driveway. It's not really recommended to have a garage door pressing on the cord all the time like that, but I have heard of people dealing with that by cutting a small channel in the concrete so the charging cord sits somewhat underneath where the garage door stops, but that's a bit of a troublesome solution. I guess I would wonder a little more why if the circuit can be gotten all the way to that wall, why it can't be put on the inside of that wall?
  3. P85_DA
    P85_DA Supporting Member
    Get a new electrician
  4. eprosenx
    eprosenx Active Member
    Beaverton, OR
    But yes, no issue with the unit outside. The unit has a GFCI built into it and it does not turn the power on to the cord until it is plugged into the car as an added safety feature.
    But yeah, I would not run it under the garage door. That could damage the cable or leave a crack for critters to get in... I put my Wall Connector outside and a NEMA 14-50 inside for this specific reason so I had a way to charge in both places. Normally the car sits outside though.
    -Eric
  5. Snerruc
    Snerruc Member
    Palm Bay
    Cocoa Beach Pier has wall chargers in the open on the beach and they still work. Much more severe conditions than most.
  6. Rockster
    Rockster Active Member
    McKinney, TX
    I have the opposite situation: car outside but I wanted the wall charger inside the garage. My solution was to slightly undercut the garage door frame and run the charging cable behind the door track. Now I can open and close the garage door without affecting the cable. If OP really must put his charger outside, this sort of cable routing could be a possible solution.
  7. P85_DA
    Pics pls ...
  8. Rockster
    McKinney, TX
    #8 Rockster, Jul 19, 2018
    The HPWC cable looks different because I protected the cable by wrapping it in this mesh sleeve material to keep it from getting scuffed up. The portion of the cable that resides outside hangs on a Gecko's Toes hose mount.
  9. eprosenx
    Beaverton, OR
    Nice! I would be worried about critters getting in with that large an opening...
  10. Rockster
    McKinney, TX
    So far, no critters in six months. The undercut is a bit higher than it actually needed to be because the bottom of the frame had absorbed moisture and was rotted, so I cut it away. When it's not >105 degrees outside I'll likely lengthen that frame a bit and tidy it all up by possibly anchoring the cable to the frame somehow so that it's not just laying there. I'm not in a hurry. It's just too freakin' hot out there right now to mess with it!
  11. davewill
    davewill Active Member
    San Diego, CA, US
    Yeah, it's pretty ridiculous to say there's no place in an entire garage to mount it.
  12. Dana1
    Dana1 Supporting Member
    Houston
    The Tesla guys are phenomenal. First pic is the conduit coming from the outside breaker box. The installed the conduit at the building seam and above eye level to minimize visual impact. Coming into garage...and to the wall charger. They painted the conduit. Top notch job.
  13. P85_DA
    Nice work ...how long a run ?
  14. Dana1
    Houston
    Maybe 25’ outside, 30’ inside and down to Charger.
  15. bomquito
    bomquito Member
    So-Cal
    How much did they charge you for the work?
  16. Dana1
    Houston
    It was close to $1100 (that included price of charger). You fill out an online form, with pictures, and they send quote back. About 3 weeks altogether.
  17. bomquito
    bomquito Member
    So-Cal
    Just realized the service is not available in California. I am glad you received a wonderful experience from their Charging team.
  18. P85_DA
    Great price !!
  19. eprosenx
    Beaverton, OR
    Wow, getting electricians to paint. That’s crazy. I would never guess electricians would do that in their scope of work! Did they have to go get paint from a shop too or did you have it? Does that include the HPWC price?
    In reality, that is not too hard an install, just need someone who knows how to bend pipe.
    Glad you had a great experience!
    P.S. Did they send someone else out to do the paint? How did they color match it?
  20. tentimesodds
    tentimesodds Member
    Charlottesville, VA
    I can’t even get electricians to patch the drywall hole they want to cut near my panel to add the wire out to my outdoor charger!
    $1100 for this install is a steal if it includes the HPWC. Still getting quotes on my install but the first one was $675 not including the HPWC, and that’s only a 25’ run with mounting the HPWC on my porch—no painting or anything.
